Results 1 to 10 of 13
January 18th, 2013 09:07 AM #1
A20
Visit their official fan page!:
https://www.facebook.com/pages/Dong-...ref=ts&fref=ts
January 19th, 2013 11:29 AM #4
okay yung humvee knock out nila ah, magkano kaya yun?
edit: ngek, 750mm lang fording ability. mas mataas pa capability the chevrolet colorado/trail blaiser.Last edited by yebo; January 19th, 2013 at 11:33 AM.
- Jun 2012
- 4,448
January 19th, 2013 02:51 PM #5
January 19th, 2013 04:06 PM #6
dun sa FB fanpage na post ni TS eggman, https://www.facebook.com/pages/Dong-...ref=ts&fref=ts
Chinese Hummer H1 For Sale in the Philippines | Dong Feng EQ2050 Series - High Utility Mobile Vehicle (HUM-Vee) | CustomPinoyRides.com - Pinoy Pride In Our Rides!
http://custompinoyrides.com/wp-conte...y_soldier1.jpg
Specifications:
Maximum speed: 105 kph
Minimum turn diameter: 15 m
Payload: 1500 kg
Deep Water Fording: 750 mm
Curb weight: 3320 kg
Deep Water Fording (with kit): 1200 mm
Gross vehicle weight: 5000 kg
Trench crossing capacity: 700 mm
Max. Towed load: 2000 kg Max.
Continuous running distance: 600 km
Maximum slope: 60 %
Ambient temperature (centigrade): -41 ~ +55
Maximum side slope: 40 %
Altitude: ?5300 m
Engine Type: EQB150-20, in line, exhaust turbo charger, diesel
Displacement: 3.9 L
Power: 112 kW (150HP)
Torque: 502 N.m
Main tank capacity: 76L
Auxiliary tank capacity: 39L
Clutch: Single plate, dry type, diaphragm spring, hydraulic remote controlling.
Transmission: Mechanical manual control, 5 speeds. Power take off optional.
Transfer case: Full-time four-wheel driven, two speed, locking, chaindriven.
Axles Final drive and geared hub connected by constant velocity universal joint.
Suspension: Front and rear both double-A independent suspensions, coil spring, hydraulic shock absorber.
Frame: Ladder structure, longeron section is box-closed.
Steering: Hydraulic power steering system.
Brakes: Hydraulic twin circuit braking system, both disc brakes, four-channel hydraulic ABS with ASR.
Wheel and tyre: 37×12.5R16.5 tubeless radial tire, split rim. Equipped
with tire pressure regulator system. Front, rear tire filled and deflated separately. Pressure can be reduced to 150 kPa.
Electrical: 24V circuit system, negative ground.
Body: Body chassis frame construction, a wide range of body forms.
Special equipment (optional): Electric winch, Air-conditioning, Runflat tire system, Weapon bearing arm.
Transportation: Transported by aircraft, ship and train, airdropped, slung under a helicopter.
The First unit has already arrived in Manila.
For the price, contact Raymond: +63 917 5258535
February 6th, 2013 09:54 PM #7
ampogi naman ng humvee copy. cavite fabricators lang katapat ng headlight and grill nyan... ayus na ang buto-buto ;D
July 28th, 2013 04:31 PM #8
Mahal din pala ng binebenta nila..
Yung HX30 nasa 800K,yung second generation Nissan Sylphy-clone na A20 nasa 980K at yung Nissan Frontier-clone na may campershell na SUV daw ay nasa 990K Pesos.
July 28th, 2013 05:39 PM #9
May pricelist ka, Eggman?
Curious ako sa presyo nung Humvee clone. Ang ganda ng interior sa pictures.
Nakakita ako ng A60 sa personal. Napa-tatlong tingin ako kung anong kotse yun. China car pala. Hindi kasi mukha.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
