A20
Visit their official fan page!:
https://www.facebook.com/pages/Dong-...ref=ts&fref=ts
A20
okay yung humvee knock out nila ah, magkano kaya yun?
edit: ngek, 750mm lang fording ability. mas mataas pa capability the chevrolet colorado/trail blaiser.
dun sa FB fanpage na post ni TS eggman, https://www.facebook.com/pages/Dong-...ref=ts&fref=ts
Chinese Hummer H1 For Sale in the Philippines | Dong Feng EQ2050 Series - High Utility Mobile Vehicle (HUM-Vee) | CustomPinoyRides.com - Pinoy Pride In Our Rides!
http://custompinoyrides.com/wp-conte...y_soldier1.jpg
Specifications:
Maximum speed: 105 kph
Minimum turn diameter: 15 m
Payload: 1500 kg
Deep Water Fording: 750 mm
Curb weight: 3320 kg
Deep Water Fording (with kit): 1200 mm
Gross vehicle weight: 5000 kg
Trench crossing capacity: 700 mm
Max. Towed load: 2000 kg Max.
Continuous running distance: 600 km
Maximum slope: 60 %
Ambient temperature (centigrade): -41 ~ +55
Maximum side slope: 40 %
Altitude: ?5300 m
Engine Type: EQB150-20, in line, exhaust turbo charger, diesel
Displacement: 3.9 L
Power: 112 kW (150HP)
Torque: 502 N.m
Main tank capacity: 76L
Auxiliary tank capacity: 39L
Clutch: Single plate, dry type, diaphragm spring, hydraulic remote controlling.
Transmission: Mechanical manual control, 5 speeds. Power take off optional.
Transfer case: Full-time four-wheel driven, two speed, locking, chaindriven.
Axles Final drive and geared hub connected by constant velocity universal joint.
Suspension: Front and rear both double-A independent suspensions, coil spring, hydraulic shock absorber.
Frame: Ladder structure, longeron section is box-closed.
Steering: Hydraulic power steering system.
Brakes: Hydraulic twin circuit braking system, both disc brakes, four-channel hydraulic ABS with ASR.
Wheel and tyre: 37×12.5R16.5 tubeless radial tire, split rim. Equipped
with tire pressure regulator system. Front, rear tire filled and deflated separately. Pressure can be reduced to 150 kPa.
Electrical: 24V circuit system, negative ground.
Body: Body chassis frame construction, a wide range of body forms.
Special equipment (optional): Electric winch, Air-conditioning, Runflat tire system, Weapon bearing arm.
Transportation: Transported by aircraft, ship and train, airdropped, slung under a helicopter.
The First unit has already arrived in Manila.
For the price, contact Raymond: +63 917 5258535
