Results 11 to 20 of 23
June 8th, 2010 08:20 PM #11
Possible na masyado mababa ang idle kaya ganyan. Yung Optrages A/T ko noon 900 RPM ang idle
Or pwede rin engine support.
Basta hindi normal yan. Hindi naman talaga dapat ganyan ang kotse eh. E hindi naman Diesel ang Optra.
At kailan pa naging normal ang malakas na engine vibration?
- Mar 2009
- 100
June 9th, 2010 10:08 AM #12kung yung dati mong optra 900rpm nya eh me slight problema yung dati mo ng kotse. ang pinaka-normal sa idle is 750-800rpm . pag nag-engage ang aux fan+thermostat 1000rpm. so yung optra mo dati me kalakasan sa gas...
maski magpalit ka ng engine support me vibration pa rin yan. sa mga well maintained or new unit lang me possibility ang minimal vibration ng engine, depende sa kalibre o status ng makina ng kotse yan... kung 2nd owner naman ang stats, maaring yung previous owner eh nagtipid at kung kanino lang pinapalitan ang timing set. kase pag wala sa timing ang makina, yan at dyan me malakas na engine vibration lalo na sa low rpm. kaya maski diesel o gas makina ng kotse mo kung me problema sa timing e magiging normal yung me malakas na vibration hanggang maitama ang timing ng makina.
June 9th, 2010 10:32 AM #13
bili ka brake cleaner kung kaya mo ikaw na lang mag linis ng intake assembly like from air-box to MAP sensor then throtle assembly baka madumi na kaya nag aadjust computer mo to compensate... tipid solution ito pero only if you know what your doing. if not bring it to somebody na may alam.
also tama sila check your engine support malamang basag na. mura lang yan!
June 9th, 2010 10:39 AM #14
Ok lang kahit 900RPM ang idle ng Optra ko, at least walang vibration. Tsaka kalakasan sa gas? The hell I care, may pang gas ako. ;)
- Mar 2009
- 100
June 9th, 2010 03:35 PM #15
- Mar 2009
- 100
June 9th, 2010 03:35 PM #16
June 9th, 2010 07:34 PM #17
Oo nga. Lintik naman talaga konsumo ng gasulina ah. Pero sinabi ko ba sa kabilang thread na wala akong pang gas?
June 9th, 2010 07:36 PM #18
dndk2007:
Sinabi niya na malakas ang gas ...
Pero, wala siyang sinabing wala siya pang gas sa 2nd quoted message mo from him ...Last edited by renzo_d10; June 9th, 2010 at 07:38 PM.
June 9th, 2010 09:19 PM #19
mga dating po kayong owners ng optra sir?
hindi niyo po kasi mapapansin yung engine vibration na sinabi ko kung hindi pa kayo mag coconcentrate, saka sobrang slight engine vibration lang kelangan nakahinto at tahimik kelangan mo talaga pakiamdaman.
HINDI PO MALAKAS ANG VIBRATION.hehe
sige po papacheck ko yung engine support 06'optra LS yung sa akin M/T. saka yung idle. nandito pa kasi ako sa sg. asa bahay lang un kotse.
pinalitan na din po kasi yung head gasket sa top ng makina kasi my leak. same time na pinalitan yung spark plugs. kaya ako nag palit spark kasi nag jejerk sa mga 1st 2nd at 3rd gear un palyado na pala plugs nya dun na din nakita yung small leak sa top kaya pinapalitan ko na din ung gasket.
ngayon ok na ok naman takbo nya dinala ko pa nga ng quezon eh. yun lang talga problem ko.
balak ko na nga ibenta to para pang down ko ng city para bago na. magkano kaya mabenta to?hehe
Yung timing set (timing chain) hindi pa po nag papalit kasi 44k pa lang po odo nya eh mag 4yrs old n si optra ko. hehe
yung maintenance prang pareho lang po kasi lahat ng parts n binili ko halos pareho lang po ang price compared sa toyota.
June 9th, 2010 09:51 PM #20
May kotse akong nasakyan minsan ganyan ang nangyayari. nagkakaron ng vibration.
Yep dati akong may Optra.
In our case, the thermostat was removed. But yes, if the thermostat is stuck open, it might show...
low idling during cold start
