Results 1 to 10 of 23
June 3rd, 2010 12:05 AM #1
Ano po kaya problema ng optra ko pag naka neutral po sya di consistent yung nginig ng makina nya? ok ung vibration tapos biglang my slight ka na mararamdaman na hindi parehas na vibration. hindi mo sya mraramdaman pag di ka nagfocus/nagconcentrate.hehe
Nagpalit na ako ng spark plugs NGK kasi nag jejerk nun tapos nawala ung jerk sa 1st, 2nd at 3rd gear.
Yung rpm ko po naman ay normal lang 1000rpm pag start tapos baba ng 900rpm pag naka neutral.
ano po kaya possible na problema?
- Jun 2010
- 23
June 6th, 2010 10:24 PM #2eto ata yung nararamdaman ko ring parang titirik makina pag naka idle lang.
June 6th, 2010 10:44 PM #3
hindi sya titirik sir, tuloy p din takbo ng makina. sobrang slight na vibration lang mararamdaman mo pag naka idle ung makina. hindi ko nga alam kung ano to eh.
HELP!
June 6th, 2010 11:18 PM #4
HELP!
- Mar 2009
- 100
June 7th, 2010 10:09 AM #5normally, ma-experience mo yan on optra's 4+yrs old manual. if my experience is the same, yan ay yung pag-automatic ng cooling system. meaning once nag-ignate yung a/c thermostat nagkakaroon ng change in its idle+the engine's automatic blower running.
kung sakali naman na once nag-ignate ang a/c thermostat and you'll notice a fluctuation sa rpm mo, yung halos parang mag-shut down yung engine's idle is me problema ang timing ng auto mo.
or
check your spark plugs tension wires. baka me putol o loose contact. but be very carefull when pulling it off kase me proper positioning yung mga tension wires.
June 7th, 2010 12:00 PM #6
hindi kaya nag-eengage yung aux fan kaya nag-vvibrate?
yup, normal lang 1KRPM upon start-up. after a few mins, bababa yan.
June 7th, 2010 07:34 PM #7
hi, never pa naman na parang mag shushutdwon yung optra ko. lagi lang syang ganun pag naka idle normal ang vibration tapos my slight n engine vibration na mararamdaman. sa power ganun pa din. tama ka 4 yrs old na yung manual na optra ko.
Ano kaya maganda gawin dito? cge papacheck ko yung wires. hindi kaya yung tensioner? kasi nagpalit ako dati ng timing belt yung sa labas di ako nag palit ng tensioner.
Hay, sana umayos a ulit.
di ba delikado to?
or baka my madamage sa engine?
June 8th, 2010 11:01 AM #8
baka nag triger lang aircon compresor kaya may kinig.. or imagination mo lang yun at theres really nothing wrong with your car.
June 8th, 2010 07:38 PM #9
dati kasi hindi sya ganun, dati swabe ang vibration hindi mo alam na nakabukas pala ang makina. nag try na ako patayin yung aircon ganun pa din po eh.
help help help! baka kasi lumala eh.
June 8th, 2010 08:00 PM #10
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
