Results 11 to 20 of 33
December 12th, 2011 12:57 PM #11
Baka next time di lang oil ang tatalsik kapag habang umaandar e buksan ang di dapat buksan.
- Jun 2011
- 251
December 12th, 2011 08:18 PM #12personally speaking lag... buy ad sell ako ng oto dati for years
binubuksan ko ang oil cap kung may talsik na oil.
at deep stick din pati kung may usok or talsik.
kung meron malaki ang tinatawad ko sa seller kkasi papagawa ko pa yun sigurado dahil ang bibili rin sakin is gaun din ang gagawin.
try nyo mag benta sa may alam sa makina sure ako na gaun din ang gagawin.
marami na kaming optra na ginagawa talsik sa oil cap pwede pero koting konti lang pangit din kasing wala kasi mahina ang bomba ng langis pag ganun.
sa deep stick kasi. pag may talsik na means na yung pressure sa piston lumulusot na papuntang ilalim.
nasa likod kasi yung overflow nya.
for us sa optra na talsik sa oil cap at deep stick its not normal at all.
December 13th, 2011 01:16 AM #13
Hindi lahat ng me talsik ng oil pagbukas ng oil cap when the engine is running e me problema. Depende din yan sa design ng engine at ng valve cover. And it's dip stick. Not deep stick. You dip it to gauge the oil level.
December 13th, 2011 01:42 AM #14
sir paki-explain nga pano maaayos ng over-haul ung problema ni sir garythyron? kasi sabi nga ni sir yapoy86, bakit kailangan buksan ung oil cap habang umaandar ung makina? at 37K km ODO, napaka-aga naman para i-over-haul nung makina tapos wala naman kapansin-pansin na drop sa engine performance.
BANNED BANNED BANNED
- Jun 2011
- 125
December 13th, 2011 08:53 AM #15this is similar to a doctor prescribing an open heart surgery without having seen the patient yet and without the preliminary diagnosis.
it might be just a heartburn from spicy food. it has always been said, "don't cross the bridge before you get to it"
- Jun 2011
- 251
December 13th, 2011 09:56 AM #16mahirap din kasing magsabi pag di pa nakikita eh
malay mo baka naman tumalsik lang yung langis pag bunot ng DIP STICK
optra overheat talaga ay ang kanyang sakit.
meron din kaming ginagawa na less than 60k complete overhaul.
ang nagiging problema ay oil pump at tagas ng tubig
ask natin kung magkano nya nabili.
December 13th, 2011 10:15 AM #17
- May 2004
- 903
December 13th, 2011 12:13 PM #18Ang sinasabi is when you are about to buy the car na pag may talsik may possibility na may problem yan.. pwedeng maliit lang pwede din na malaki.. now if you own the car iba yun kailangan mo muna pa diagnose para to pin point yung problem... and hindi po lahat eh pwede natin base sa milage ng sasakyan.. pero ang milage ay isang gabay din...
- Nov 2008
- 13
January 19th, 2012 02:24 PM #19Ano po ba problema sa aircon ng unit ko (optra). After 30 mins or 1hour nagwa-warm na lang. Kelangan pag patayin. Rest for a while den on uli.(vice-versa). Please help.from Mindanao po ako
- Jan 2008
- 4,726
January 19th, 2012 02:35 PM #20check your auxiliary fans... they might not be working properly resulting to system high pressure
high idle RPM at engine start
