Results 11 to 12 of 12
- Jun 2010
- 23
October 17th, 2010 09:16 PM #12
yup sinabi rin sa akin ng mechanic yan.
pero what started the overheat in the first place, sa tagal kong inisip kasi walang leak at yung sister ko ang madalas gumamit. alam mo naman tipong usual lady drivers, drive lang alam at la nang paki sa oil,fluid,coolants etc
di siguro napansin ubos na yung coolant kaya bumigay ang thermostat housing.
as long as palaging may coolant basta wala lang leak, okay ang both plastic or steel thermostat housing.
side tip for others na mapunta dito, as recommended by other tsikoteers here - mas maganda 50/50 coolant at DISTILLED water kaysa sa pure coolant lang.
high idle RPM at engine start
