Results 31 to 40 of 40
- Sep 2013
- 23
April 30th, 2016 07:15 AM #31
- Jul 2013
- 3
May 5th, 2016 08:00 AM #32good morning mga sir. newbie here. thankful at may thread pala na ganito. not sure kung pwede magtanong kung san pwede bumili ditto ng parts. anyway, yung hinge ng backdoor, top gasket and saan pwede magpatingin ng alternator? TIA
June 4th, 2016 06:58 PM #33
Bozz Jun
Im from Laguna, medyo malayo sa shop mo. My :
My ride is Optra Wagon 1.6LS 2006. For about a year already or more, maybe 2 years na..nagkaroon siya ng problem, hard starting. Pero walang check engine indicator light on. Eventually, it loses power until ayaw na mag start. Eventually, fuel pump ang problem, may butas yung orange hose. Pinalitan ito ng normal hose from old salvaged parts ng ibang sasakyan..ordinary fuel hose, nilagyan lang ng clamp. Umandar nman pero it needs about 3x cranking bago mag start. I continued using it pinagtyagaan lang.
Pero after a year orso ng tyaga, napansin ko na nawawala power niya specially kapag newly started. Lalu na kapag naka todo liko...ayaw umandar. Tapos kahit na umaandar na, namamatayan siya pero hindi palagi
Now recently, umilaw yung check engine..obd2 check is crankshaft sensor. Pinalitan ko kanina. Nawala yung check engine...pero yung loss power and 3x cranking hard start..ganun pa din. Sabi mechanic..intay daw mag a adjust daw computer. I doubt it. One more..bilis maubos ng coolant..
Things replaced in the past.
1. Fuel line dahil kinagat ng daga..bigger ata diameter ng inside.
2. Fuel pump internal orange hose made regular hose
3. TBA cleaned with spray from ace hardware
4. My fog lamps have water inside mula nung binaklas bumper when it was repaired after a motorcycle bumped it.
5. Today I changed the crankshaft sensor.
I want to go to your shop kaso sobrang layo, kaya gusto ko muna DIY yung checking. Saan ba makikita yung Map Sensor and hose?
Thanks...sobrang haba..desperate na kase
- Jun 2016
- 1
June 19th, 2016 03:20 AM #34Hi! Bago lang po ako post sa mga ganito. I'm from Cavite. Ask ko po sana kung may alam kayo parts at mechanic na may alam ng chevy dito sa Cavite? Chevrolet Optra 2004 po sakin.
Yung sasakyan ko kasi ayaw na magstart. Mga months na din ng unang napansin ko na parang pumapalya ang takbo ng sasakyan ko pero still tumatakbo parin naman at mejo hirap mag start. Napacheck ko sya sa mga shop dito pero di parin nasolve. Hanggang last month napansin ko na nawawala na busina ko tapos kinabukasan nagcheck engine. Pinapalitan ko busina pero di parin nawala chech engine. Based sa computer box IAT error daw at kailangan palitan ng ECT. Pati servo -tps daw kailangan din palitan para maganda na tiempo ng sasakyan. Pinalitan din bago starter at pati MAP pinalitan. Pinaremejo ko muna para magamit ko. Nauwi ko yung sasakyan pero mas lalong ala na sya power sa pagtakbo at kinabukasan ayaw na magstart.
Nagtry din ako contact kay boss Jun sa forum dito. Nakausap ko sya over phone and text nung una para sched dapat ng weekend daw pero ngayon di ko na makontak no. nya. Di ko naman mabyahe sasakyan kasi sira. Ayaw ko din sana puro bili ng bili ng bagong pieza na parang nagpa casa na ako at wala namn kasiguruhan.
Sana po may makatulong. Salamat.
- Jan 2016
- 3
July 20th, 2016 11:14 PM #35hi boss jun,
im newbie here, may chevrolet optra 2004 LS A/T po ako, when magdrive po ako.. medyo ma ugong yun makina, malakas tunog sa loob ng kotse, normal po ba yun?
compare kasi sa ibang car, mahina lang tunog andar ng makina eh,
thanks, God Bless!
- Jul 2013
- 3
August 12th, 2016 07:36 AM #36Up.
Sir makikiride ako sa thread mo. Pag nasa stop ako then shift to Drive or Reverse, nanginginig yung kotse pag naka aircon. Di ko sure kung engine/trans mount or idle up sensor or kung ano na. kakapalit lang spark plugs and top gasket.
Nangyayari rin sha pag pa menor na ko at naka drive ako. 2006 LS A/T.
TIA
- Sep 2016
- 1
October 4th, 2016 04:10 PM #37
- Mar 2018
- 1
March 2nd, 2018 10:11 PM #38Sir jun, good evening!
I have a chevrolet optra 2009. 98k odo. Bigla na lng nag CHECK ENGINE. Nung pina scan ko, ito ang result: PO342-CAM ANGLE SENSOR VALVE LOW.
Need help! Thank you!
Sent from my Redmi Note 4X using Tapatalk
- May 2018
- 1
May 23rd, 2018 07:13 PM #39
- Jun 2019
- 7
June 3rd, 2019 12:13 PM #40
Kicks, yes. Leaf, no.
2021 Nissan Leaf
