Results 3,231 to 3,240 of 4415
March 28th, 2013 09:09 AM #3231
Hi Audrey!
By the way, congrats on your new TrailB ride. That is exactly the same experience i have with regards to speedcams. I also had an experience regarding overspeeding that it blurted out something i really cant remember even if i didnt set any speed limit through the TrailBs menu function.
March 28th, 2013 09:14 AM #3232
To dsjamd:
Congrats also on your new TrailB!
I agree with sir albert that you should check your tires psi. From casa my psi tire pressures were 37-38 kaya matagtag initially but when i tried using lower psi the ride became excellent.
- Dec 2012
- 293
March 28th, 2013 12:55 PM #3234
- Dec 2012
- 25
- Mar 2013
- 6,160
March 28th, 2013 02:57 PM #3236How do i use the USB of the headunit? Its a mini usb port. Wierd choice of port.
Sent from my iPad using Tapatalk HD
- Dec 2012
- 293
March 28th, 2013 04:11 PM #3237
- Dec 2012
- 185
March 28th, 2013 04:44 PM #3238The mini USB available is not for charging but for data. Maganda sana kung regular USB size na ang nilagay ng Chevrolet so we do not need an adaptor. If we have songs and music stored in USB flash drive, we need a mini 5PIN to USB AF connector available at CDR King for PhP50 to be able to play it on the existing HU. You can also have a cable USB OTG adaptor available at Phoenix Tab in Mega Mall at PhP 400. From your IPhone or IPad using bluetooth, you can listen music from the the 8 speakers of the TrailB.
- Mar 2013
- 6,160
March 28th, 2013 05:01 PM #3239
- Jul 2006
- 3,376
March 28th, 2013 06:43 PM #3240The iPhone and the iPad can't play music through bluetooth of the stock HU. The stock HU's bluetooth only has phone functions. I tried syncing my Galaxy Note 2, my iPad and my former BlackBerry using bluetooth to play music through the stock HU, but it can't.
If you want to play music using your iPhone, iPad and other USB flash drives, buy a mini USB to USB adapter at CDR-King. I bought mine last January for 80 pesos.
high idle RPM at engine start
