Results 11 to 18 of 18
July 16th, 2007 07:07 AM #11
sir joey, about dun sa LED ng alarm dun sa dash, normal nman yung speed ng blinking interval nya.. ngayon kse nakatanggal yung negative terminal ng battery eh, everytime na knoconnect ko na ulit, ARMED na agad yung car alarm..since the remote doesn't work, hindi ko ma disarm, eventually hindi ko ma-start yung kotse dahil sa ignition cutoff feature...
eto po yung laman loob ng alarm system ko... i hope you guys could point out which terminals i should short para ma-bypass yung alarm, better yet kung may idea rin po kayo, plano ko sana lagyan na nung bypass switch para kung pwede pa nman pla to, hindi na muna ko bibili ng bagong alarm system...
much thanks mga bro...
July 16th, 2007 07:52 AM #12
July 16th, 2007 08:01 AM #13
maybe ung AGC means "at alarm armed w/d ground connection" kaya pwde rin maglagay ng starter kill relay d2, pero wala ka nakitang relay jan dba? trace mo lang muna sir
July 16th, 2007 09:58 AM #16
sir pano gagawin ko? short ko lang yung ST0 and ST1 then turn the ignition on? what about the AGC? ano gagawin ko dun?
thanks...
July 16th, 2007 10:27 AM #17
remove the wiring harness sa alarm module trace mo muna ung STO n ST1 pag ang end wire nya e nka top sa same color na wire sa wring harness under ng steering collum sa may ignition switch, makikita mo naman un na pinutol nla ung wire at sa ST0 and ST1 nila knabit. go for it na connect muna ST0 n ST1 and cover muna ng electrical tape and it should be tight ang pagbond mo nung wire.
start the engine!
if ever na hindi ka cgurado sa gagawin mo at dmo masyado magets ung cnabi ko, kung manual tranny ESi mo sir ito gawin mo remove alarm module then turn ignition key to ON position at magpatulak kana kadyot start ba at dalin mo sa nearest electrician na kilala mo.
Xiaomi E-Car
