Results 1 to 10 of 20
- Jul 2012
- 329
December 4th, 2012 06:51 AM #1mga sir need your help.. yung lock ng car ko wont work using the remote pero tumutunog naman at nakikita ko umilaw, it's just that hindi sya nag uunlock or lock kapag ginagamitan ng remote, i have to use the key. napalitan ko na batt ng remote. nag rerespond naman alarm kasi tumutunog using remote pero ayaw mag respond ng lock.. anu po kaya ang problema? laguna area po ako. thanks!
December 4th, 2012 09:30 AM #2
December 4th, 2012 09:32 AM #3
Baka ung sensor may problema, ung remote mo is not communicating with your car.
- Dec 2012
- 1
December 4th, 2012 01:42 PM #4This is common issue when circuit switch fuses. Just replace the switch allotted to central locking system, it will for sure. I have done with it.
__________________
Get paid more with delivery jobs
- Jul 2012
- 329
December 5th, 2012 11:33 AM #5dati po gumagana.. nag rerespond nmn ng tama yung lock sa remote.. gulat lang ako bigla nlng hindi na nag respond. nakikita ko yung nlock it's trying to "lock" pero hindi tumutuloy.. parang nahihirapan. separate po ba ang batt nung actual sa lock system sa batt ng remote? thanks mga sir.
December 5th, 2012 12:43 PM #6
could be the central lock apparatus. baka busted na or loose yung rod connections.
Tsikot Member Rank 4
- 2,719
December 5th, 2012 02:51 PM #7
- Jul 2012
- 329
December 5th, 2012 04:09 PM #8can i fix this alone or should i seek help from experts. naisip ko rin na baka nakaka affect yung driver side power window kasi nagloloko rin yun pag taas at pag baba nung window.. diba po dun yung main lock switch ng mga car?
December 5th, 2012 04:54 PM #9
- Jul 2012
- 329
December 5th, 2012 09:25 PM #10mga sir just incase i decided to change the alarm system, ano po marecommend nyo ipakabit ko?
TopGear taking a cue from journalists scouring patent applications of tech companies.
Mitsubishi Philippines
