Baka ung sensor may problema, ung remote mo is not communicating with your car.
This is common issue when circuit switch fuses. Just replace the switch allotted to central locking system, it will for sure. I have done with it.
__________________
Get paid more with delivery jobs
dati po gumagana.. nag rerespond nmn ng tama yung lock sa remote.. gulat lang ako bigla nlng hindi na nag respond. nakikita ko yung nlock it's trying to "lock" pero hindi tumutuloy.. parang nahihirapan. separate po ba ang batt nung actual sa lock system sa batt ng remote? thanks mga sir.
could be the central lock apparatus. baka busted na or loose yung rod connections.
can i fix this alone or should i seek help from experts. naisip ko rin na baka nakaka affect yung driver side power window kasi nagloloko rin yun pag taas at pag baba nung window.. diba po dun yung main lock switch ng mga car?
mga sir just incase i decided to change the alarm system, ano po marecommend nyo ipakabit ko?
[QUOTE=nashimoto;2051957]dati po gumagana.. nag rerespond nmn ng tama yung lock sa remote.. gulat lang ako bigla nlng hindi na nag respond. nakikita ko yung nlock it's trying to "lock" pero hindi tumutuloy.. parang nahihirapan. separate po ba ang batt nung actual sa lock system sa batt ng remote? thanks mga sir]
defective na yang driver side motor/actuator hindi na kaya hilahin yung lock/unlock rod..just replace it with an aftermarket actuator it just cost less than P200/pc, yung may 5 wires kunin mo.
