Quote Originally Posted by vickydean1128 View Post
Pwede po bang magask din about sa alarm system.new lang po akondto sa forum.ang car ko is mitsubishi adventure model 2017. Nabangga po ako from behind then namisaligned po ang clip sa likod sa back side so medyo bumaba sya konti then yung door parang ayaw nya tuluyang magclip though pag pinindot ko alarm nglolock naman sya.ang problema from then on mdalas n magloko ang alarm system.bgla bgla n lang sya magaalarm kahit sarado n mga doors.after few minutes magaalarm n naman.tpos napansin ko yung ilaw ng dashboard on the car laging naka on n sya.then today since 1am every now and then nag aalarm yung car.nung nagcheck ako.naisara ko naman sya maayos pero yung ilaw malapit sa susian nag rered then green.so kahit nalock ko na ulit lahat ng door nagaalarm n naman sya. May koneksyon po ba sya sa naging bangga ko? At need ko maipaayos yung pinto ko sa likod at yung n misaligned na prang bumper sa likod pra maglock ng todo yung pinto?.pahelp po nakakhiya n sa mga kapitbahay hatinggabi myat mya nagaalarm sya.
Temporary remedy is to disable the alarm. What's happening most probably is that since the door is misaligned, the sensor will detect that the door is open and so will trigger the alarm even though the door is closed.
Check the door, there should be a rubber like button that sends the signal if the door is open or not.
