sa mga naghahanap ng mahabang usb cable to connect their sjcam to the cigarette lighter via a pillar, may 3meter cable sa monster cable sa sm.
Hi guys, I just bought an action cam from cd-r king (model 006 - with car mode). I have a question about its automatic on/off feature when detecting power from the cigarette lighter source. When I turn the car off, the cam automatically switches off. But it wont turn on automatically when I start the car. Is this normal? Sayang naman nabitin pa ng feature ung action cam ko.
Mga sir, need advise g1w-c vs sj4000?
Ano mas ok? Pros and cons of each model po.. Please help.. Thanks.
Bro post naman ng setup mo.
Thanks!
I ended up buying Transcend DP220 at TCA.
Ang kulit ng taga Blade pero di niya alam pinagsasabi nya.
Less 5% sa TCA pag cash.
So far OK naman ang performance.
Problema lang e suction cup siya kaya weekly e ina ayos ko yung mount to make sure.
But if you can get a g1w rearview mirror mount, mukhang compatible siya.
confirmed ba na kasya sir? may nakita kasi ako nagbebenta sa fb e
https://www.facebook.com/itemshop.ph?fref=ts
If anybody os intrested with my sj4000 non wifi(orig & tested) just pm me. With 8gb mSD & rear view mirror mount.
Got a gorillapod to mount my sj4000 on the rearview mirror stalk before I figured out that the screw on mount is adjustable. At least I can use it as a tripod lol
ganyan din isa sa naisip ko na pag-mount pero hindi talaga pwede dahil sa rear view mirror ko. kahit ilang attachments pagsama-samahin ko, di talaga magfit.
suction mount lang talaga pwede.
Im interested ... Anyone here from Cavite or from McKinley Hills? Para I can personally give the cash payment via meetup ... Im not used to online transaction eh
Hi Kimot,
Ilang beses ng bumigay yung suction mount
Buti na lang, naka tali sa rearview stalk yung usb cable kaya hindi bumabagsak yung DP220...
I think standard yung saksakan nila like g1w dahil yung 2 suction mount ko for cell phone e puede rin sa dp220 ... But its bigger and bulkier than the dp220 suction mount.
Hence, the search is on for g1w rearview stalk mount![]()
I ordered this through geekbuying.com and cost me $85 plus shipping as it is coming from China. I will share a review and a video sample as soon as I receive it.
Product Description
Highlights178 degree super wide angle lens.2304*1296/30fps high definition resolution.Advanced H.264 video compression technology.2.7 inch high resolution LCD, can view while recording.Support HDMI high quality video transmission.G-Sensor to keep the record of sensor data at emergency cannot be coverLoop recording with seamless, does not leak second.Automatic circulating recording, it’s able to set the record time for each file.Watching video simultaneous while driving, supporting on-spot play back.Time & date display changed, there is no need to reset when re-starts.A key to lock functionMotion detection functionAutomatically turn on/off functionCan charge and transmission through USB.Equipped with special car fixed sucker, easy to fix and use.Maximum memory storage 32GB, or TF with more high capacity storage device.
