I am using both DP230 and 520 and so far I am satisfied. It is bulky though. Funny experience is when I used the 230 as rear facing dashcam installed at the lift gate. It got confused with the reverse direction of the road markings and the reverse speed I had to switch off the lane departure assist and speed limit functions. After that, it went back to normal.
Sa mga may windshield tint, pano nyo po kinabit yung dashcam? Nabasa ko na nakakasira ng tint yung dashcam depende sa pangkabit niya.
No GPs signal... probably hindi pa napipick up ang signal or mahina...
But this time it has...
Always ba na walang signal sa expressway? Before ka dumating sa expressway may signal pa and pag dating sa dun nawala? Baka walang gps or mahina lang? Baka may jammer dun sa area? Hehehe...
Sometimes tint may interfere in locking gps signal.
Sent from my iPhone X using Tapatalk
Not good. Kailangan ko ata ipa-replace yung dashcam. Although I am not sure paano ang warranty since it was ordered online.
Akala ko parang yung nangyayari sa xiaomi yi ko wherein bigla na lang steady-led at hindi nagrerecord (see my older posts, caused probably by a fluctuation in the voltage/current). pero once you reboot the yi, or plug/unplug the powercable, okay na ulit.
refer to the attached picture. it suddenly started recording 0 bytes. tapos kahit next day na, puro 0 bytes pa rin. it stopped recording at 5.8gb. the card has 16gig capacity. the yi is easier to spot pag nagloko ang recording since kita kaagad dahil sa led saka nasa harap siya. yung 70mai medyo mahirap since nasa likod.
i will investigate further.
