Page 146 of 176 FirstFirst ... 4696136142143144145146147148149150156 ... LastLast
Results 2,901 to 2,920 of 3510
    Sep 2010
    #2901
    Quote Originally Posted by millsguevarra View Post
    Hi Sirs, naghahanap ako ng pwede mag install ng dashcam na hardwire. Hindi kasi ako marunong. Any recommendations?
    Thanks!
    Read somewhere that Goldcars in banawe can do it.
    #2902
    Quote Originally Posted by robot.sonic View Post
    Try mo muna yung hinde hardwired. Ganon din kasi gusto ko dati kaso wala pa akong nabibili na kit. Di ko naman napapansin yung wires (power socket ko malapit sa floor) kaya hinayaan ko na.
    I agree with this. This is my car's interior - nakasaksak lang sa 3-port 12V USB charger yung dashcam but hindi halata at all.
    #2903
    bro di mo ginamit yung supplied USB cable nun camera?
    #2904
    No bro because I also use my 12V port to charge my phone so I use a 3-slot USB charger from Capdase with fast charging capability which I need for my Samsung phone.
    #2905
    ah oki thanks, worried ako na baka 12v supply need nya.
    #2906
    Nauna pa dumating yung dashcam kaysa yung OR/CR ng kotseng pagkakabitan. [emoji23]
    New car? nice! ;D
    Jun 2011
    #2907
    Thanks for the recommendations sirs! Akala ko kasi if gusto ko nalang tago yung wires kailangan hard wire.. So Bali dinaan Daan lang siya sa ilalim or sa bubong para hindi siya kita Tapos saksak lang sa Power outlet.
    Kayo mismo gumagawa niyan sirs? Paano yan ginagawa? kailangan bang baklasin?
    Nov 2007
    #2908
    Here you go
    How To Hide Your Dash Cam Wiring for Clean Install - YouTube
    #2909
    Yes, DIY lang. Sa headliner, sinusuksok lang yung wires. Sa A-pillar, nakaclip lang yan (minsan screw) so madali tanggalin. Then isusuksok mo lang behind the glovebox then mailulusot mo na siya to the power outlet in your car's center console.
    All in all around 15 min to install including setting up the dashcam.
    Jun 2011
    #2910
    Thanks again sirs! Watched the video. Problema with Mazda 3 is nasa center arm rest yung power outlet. So mukhang may ma expose na wires talaga unless siguro padaanin ko sa ilalim ng upuan.. Hehe.
    Subukan ko sirs!!
    Oct 2009
    #2911
    Subukan ko sirs!!
    Yan ginawa ko sa akin bro sa montero, running the wires hanggang dun sa may pillar sa door nakatago pa rin dun sa nmay seatbelt na pillar and going thru sa ilalim ng upuan and pasok sa center console may plug kasi sa loob so wala ka talaga makita na wire and free pa yung cigar lighter plug.
    Nov 2007
    #2912
    Quote Originally Posted by forceG View Post
    good idea of using the outlet inside the center console!
    Mar 2007
    #2913
    Subukan ko sirs!!
    M3 owner here. Yung sa akin sir, pinadaan ko sa tabi ng passenger seat. Pwede matanggal at itago dun. Tapos sa ilalim ng seat at floor mat. Di naman halata pag nakakabit na sa center console at masasara naman kahit may wire.
    Sent from my RNE-L22 using Tsikot Forums mobile app
    Jun 2011
    #2914
    Thanks Sirs! Wasn't aware na may plug sa center console..
    Quote Originally Posted by gromek View Post
    Sir baka pwede magpakita ng pics? Para makita ko yung ginawa niyo.
    Jul 2003
    #2915
    *Sir Jut, asked ko lang if naikabit mo na din yung rear cam na kasama sa Mini 0906? Likewise, any noticeable issue on Mini 0906 after you installed and used it? Thanks in advance.
    Sent from my SM-J500G using Tapatalk
    Aug 2012
    #2916
    Viofo A119S v2 and A119 v2 dash cams have arrived.
    Sent from my ASUS_X00DDA using Tapatalk
    Dec 2017
    #2917
    good evening po, ask lang po sa mga dashcam users if meron na naka try ng Goluk Dashcam. Plano ko kasi bumili before mag Valentine's Day, nakita ko sa Lazada recently. Compare, compare ko yong price at specs sa Transcend at unbranded, affordable naman ang Goluk at medyo ok naman mga review...if meron po sana kayo sample videos, pa-share naman mga bossing.
    Plan ko bilihin yong T3 na black.
    Dec 2017
    #2918
    Hi All. Would you recommend me getting Transcend DrivePro 230? What are its counterparts and baka may marefer kayo na may FullHD 60fps recording aside sa BlackVue? Thanks!
    #2919
    How about the rearview mirror mounted dashcam?
    Anyone using it here? Cost is about P3K... How's your experience/assessment with/on it?
    Am currently using Transcend....
    Dec 2017
    #2920
    I was originally considering that but since yung rear view mirror ko has the electric anti-glare feature, nanghihinayang ako palitan/takpan.
    Which Transcend model are you currently using? HOw's it for a dashcam? Would greatly appreciate the pros and cons. Thanks
Blackbox DVR/Dashcam
