After a month with the Mini 0805, no doubt this is the best dashcam you can buy for 3.5k!
- Video quality is superb, definitely beats even the more expensive Transcend DP220 in night time video. Even if I have 3M CS20 tint on my windshield, I can still read plate numbers easily at night.
- GPS works very well and this is the only dashcam at this price range with the feature
- Small form factor makes it very unobtrusive and sleek
The only drawback I've observed is that it's a bit choosy with the SD card you use. I tried a class A Samsung SD and it would have an I/O error every now and then. I switched tomy orig Samsung Evo, and it had worked perfectly ever since.
Sir jut, did you install the dashcam yourself? Yan na din kasi yung binili ko but I'm worried that I won't be able to hide the cables as cleverly as you did.
Thanks.
