Page 136 of 176 FirstFirst ... 3686126132133134135136137138139140146 ... LastLast
Results 2,701 to 2,720 of 3510
    Jul 2013
    #2701
    Quote Originally Posted by red_one View Post
    It is money well spent for me.
    Not everyone needs a hardwire kit but to say that we are wasting money is rude. Imho.
    Sent from my ASUS_Z010D using Tapatalk
    I don;t know what is rude with saying that. It is an opinion. Anyway, read my post again. I already said "your money, your rules".
    Jul 2015
    #2702
    maybe its the weather
    Jul 2012
    #2703
    Quote Originally Posted by Lew_Alcindor View Post
    yan din akala ko. pero ang balak ko tap from fuse box then connect to power adapter that comes with the dash cam. that out-of-the box power adapter surely converts 12v to 5v, right?
    in my case kasi, besides sa nakakahinayang sirain, mas abala kung didistrongkahin ko pa yung cigar lighter adapter na kasama sa dashcam para ma-hardwire. tsaka yung hardwire kit na ginamit ko USB type A port, so possible na gamitin sa iba ibang type nang cable kung may bagong dashcam man akong gamitin other than mini USB type port. its more of a permanent and OEM approach to hardwiring dashcams. not necessary, but definitely not a waste of money. in my opinion.
    #2704
    Quote Originally Posted by skylightpigeon View Post
    hardwire kit is needed for 5V dashcams. kelangan kasi yung 12v to 5v adapter, hindi pwedeng rekta.
    I just used the charger that came with the dashcam. That already converts 12V to 5V.
    Jul 2012
    #2705
    is it a cigar lighter port type of charger? if so, how did you hardwire the adapter to the fuse box without disassembling the adapter?
    #2706
    We dissambled the adapter.
    Jul 2012
    #2707
    i imagine a PCB or coils to convert voltage is inside the housing? i would not know where to tap +/- wires if that is the case.
    #2708
    It's color coded.
    Jul 2012
    #2709
    It's color coded.
    are you referring to the cable wires?the ones that connect to the dashcam itself? how about the internals of the adapter, the converter itself? how did you tap the wires from the fuse box to the converter? did you leave it dangling around unprotected? thanks!
    Jul 2012
    #2710
    does your adapter look like that?
    #2711
    lahat ba ng dashcam may auto off ang screen habang nagrerecord?
    #2712
    To those who are using DP220, has anyone experienced the time changing on its own? Example I set the time to 18:00, after few minutes, magiging 10:00 siya.
    #2713
    That happens to me also. Di ko alam pano irectify...
    Sent from my SM-G930F using Tsikot Forums mobile app
    #2714
    ^i tried searching online, wala akong mahanap na same issue or solution. Firmware update kaya?
    Sep 2012
    #2715
    Using firmware 1.13 wala pa naman issue na ganyan for my DP220
    May version 2 na nga nakakalimutan ko pa lang i load
    #2716
    Quote Originally Posted by jodski View Post
    How do you load it?
    DP220 user too.
    Sep 2012
    #2717
    How do you load it?
    DP220 user too.
    Download the firmware zip file here sa site ng Transcend
    DrivePro™ 22 - Support & Download,TS16GDP22A,TS16GDP22M
    Complete na yan with the manual on how to update.
    Copy mo lang yung bin file sa system directory ng micro sd card mo
    #2718
    Thank you for the info
    #2719
    Updating to the latest firmware didnt help. Mukhang may problem talaga
    Jul 2015
    #2720
    I don't have this issue but...
    my loop recording seems to...
    naka set saken ng 1 minute, every time I start the car it revert back to default setting which is 3minutes...
    Ganito rin po ba yung inyo?
Blackbox DVR/Dashcam
