Guys pwede bang gawing dashcam ang action cam? For dual purposes kasi eh hehhee.. ano mai recommend niyo mga bossing?
Sent from my SM-N920S using Tsikot Forums mobile app
*red_one,
The hard wiring kit and fuse thingy, where did you get that? I have the older A118C installed on all vehicles and was thinking of having it done the same way. Thanks
If I may.....
Dash Cam Hardwire Installation Kit 12V to 5V Mini USB Power Supply
Cable - intl | Lazada PH
Dami pang choices sa Lazada.
Yes, I've seen them. I just want to see where red actually bought his
Sent from my ONEPLUS A3003 using Tsikot Forums mobile app
D3 Technologies
D3 Technologies - Home | Facebook
Sent from my ASUS_Z010D using Tapatalk
Thanks much. Will check them out
I realized that this hardwire kit is a waste of money. Might as just hardwire direct to the power chord that comes with the dash cam. Tap it to an aux power or cigarette ligher slot. Dash cams doesn draw a lot of power. You probably do not need to worry about busting a fuse.
What i did i connect it to the power source located inside center console box. Tama lang yung length ng wire running through the door packing then below the front seat..
_/_/_/The more things are forbidden.. The more popular they become. _/_/_/
Ako din ganyan pero kelangan ko yung power source to charge other devices kasi like pocket wifi, old phone used for GPS navigation etc naiisip ko i-hardwire. Malinis din kasi tingnan. Pero baka i-tap ko na lang yung wire ng aux power socket then connect it to the power chord of the dashcam. Sure pa ako na tama yung power na papasok sa dash cam.
DIY Guide How to tap into your cars fuse box safely and cleanly - YouTube
If it serves its purpose, then it is not a waste of money. Kaya ako naglagay ng hard wire is para maging free ang 12v cigarette lighter port and also to make wiring tidy or invisible. Which is yun nga ang naging result.
The fuse is optional. Yup, mababa lang ang current load ng dashcam. Kaya naman ako gumamit ng fuse tap is para madali ang installation. Just tap to the fuse box.
I am not referring to the hard wiring as a waste of money but rather the hard wiring kit. You can hardwire it without a hard wire kit or with a must less expensive fuse tap.
Ako mismong planning to hardwire for the same reason as yours. Pero na-realize ko unnecessary expense yung hardwire kit na ginamit mo. But anyway, your money, your rules.
Walang hardwire kit yung sakin, nakarekta lang din sa ignition and may fuse din. 300 lang kasama na labor.
SJ4000 WiFi going on 3 years now.
hardwire kit is needed for 5V dashcams. kelangan kasi yung 12v to 5v adapter, hindi pwedeng rekta.
