Thanks. Kaka received ko lang ng in-order ko na yi dashcam. Orderin ko na yan. Maganda din naman ang review ng mga bumili.
According to Car Cam Central, Samsung discourages the use of all of their SD cards for dash cameras. It was not designed for those. As the article puts it:
I would follow the manufacturer's advice on this one.Their cards are great but their policies prohibit use in a dash camera. For their MLC Samsung Pro/Pro+ it has this note beside their 10-year warranty. "Warranty is limited for any type of surveillance system."
Reaching out to Samsung Service I received this response:
"Samsung SD Cards and Micro SD Cards are not intended to be used for continuous recording purposes for example, in surveillance systems such as a car-black box. The reason for this is because the card may fail with constant and obsessive reading and writing. They are not designed to be constantly and continuously written to."
Meron Sandisk High Endurance at Transcend High Endurance na micro SD cards. These are designed for dashcams and surveillance.
Sent from my D5833 using Tapatalk
Majority of micro SD cards available are not High Endurance. Still it does not mean you cannot use them. You don't use dascams 24/7 naman eh. Yung surveillance lang ang 24/7 ang recording.
Bili ka na lang ng 64GB para matagal bago mapuno at mag-overwrite. If may available na High Endurance, yun ang buy mo. If wala, then no choice.
Well, at least 2x per year lang ako mag long drive, atleast monthly sa batangas na more or less 1 hour, and mostly pagpasok office na 15 to 30 min.
And, na order ko na.
At wala naman ako ibang paggamitan.
Yup, ok na yan. Yung iba nga generic brand micro SD lang gamit.
mga sir saan pa kaya may nagbebenta ng viofo a119?
Curious question lang, are there dashcams in the market na ang FoV eh 120 degree or less? Usually kasi ang mga dashcams sa market eh 130 degrees pataas na ang inilalabas.
Curious, why you need narrow FoV?
Hindi ba wider FoV is better so you capture more area in the video?
Capturing more area is the main positive of a wider FoV but on the flipside, objects look farther than in reality. I noticed this when I reviewed the footages from the DP200, which has a really wide 160 degree FoV lens. It's not really a bad thing, but a narrower lens gives an impression of the objects distance closer to reality.
This is just a personal preference though. I'm just hoping that dashcam manufacturers will give a selectable/adjustable FoV setting in the future so users will have a choice based on their preferred FoV, like some action cameras do para everybody happy. :D
Thanks sir. Installed na and nagamit ko na ppupunta divisoria. So far so good. Transfer of files through wifi is at 3mbps. 3min clip is at 350mb on 1080p/30fps setting. Ang kulit nga talaga ng adas. Kaya pala recommended nila to just turn it off.
Guys, sino naka yi dashcam dito? Anong gamit nyong mount to attach it sa rearview mirror? Tried matching the sjcam bike mount but it wouldn't fit. Thanks
Sent from my MI 3W using Tsikot Forums mobile app
Sa lazada ata meron sir. Dashcam holder.. Pero ako ang gamit ko pa din ay yung stock.
Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
