Quote Originally Posted by keto View Post
^^ Thanks for all the feedback regarding nighttime settings.
No windshield tint so default exposure settings seem to give me the best results. Upping the exposure to even +1/3 gives me problems with glare at night especially with light sources, ie oncoming vehicles headlamps and streetlights. The fact that I also have Phillips Xtremevision bulbs adds to this issue when it reflects on the plate number from the vehicles I'm following. The glare is so bad sometimes that it makes the plate numbers of vehicles in front of me unreadable.
I've also settled on 720p because I can set capture rate at 60fps. Will try disabling audio, as it is parang almost 1gb per 10 min yung file size.
I also ordered 5m long usb cables, will try some cable management once it arrives.
I have similar issue with glare.
I have 3M Magic Tint which is compensated by Osram Night Breaker.
Problem is, the glare from vehicles directly in front makes it hard to read the plate numbers. Even with the naked eye, its a problem.
