Page 39 of 176 FirstFirst ... 293536373839404142434989139 ... LastLast
Results 761 to 780 of 3510
    Jun 2015
    #761
    No need for 4m cables. I used the stock cable that came with my SJ4000's car charger (about 1.5-2m long), and it was long enough to hide in the headliner and A-pillars, and connect directly to the ignition so it won't use up your 12V socket anymore.
    Ohh. nag DIY ka lang dito sir? I believe we have a same car - altis 11th gen. But I have no idea paano ko ma-coconnect directly sa ignition yung cable/car charger.
    Jun 2015
    #762
    Quote Originally Posted by RC-V View Post
    Naghanap din ako nyan dati, I ended up buying usb extension and DIY install it.
    parang ganto nabili
    Attachment 27586
    Attachment 27587
    Attachment 27588
    Attachment 27589
    next time kuhanan ko din ng pics yung sa may extension usb adaptor.
    Cge sir patingin.
    parang ganto nabili
    Attachment 27586
    Attachment 27587
    Attachment 27588
    Attachment 27589
    Cge sir patingin.
    Apr 2006
    #763
    pictures naman ng installation ng sj4000 as dashcam behind rear view mirror. para magka-idea ako. ayaw ko sana kasi using the suction cup.
    Oct 2014
    #764
    Behind the rear view mirror:
    No more wires and suction cups
    Oct 2014
    #765
    On the dash board:
    Quote Originally Posted by JJ All Day View Post
    Apr 2006
    #766
    *jj yung sa dashboard nagawa ko na dati using the mounts na kasama. problem ko lang masyadong mababa (harang yung hood) tapos medyo nagvivibrate kapag umaandar (low profile tires + matagtag na ride). pag suction cup naman nadadampen yung vibration pero kita kasi mula sa labas yung suction marks saka takot ako na baka malaglag bigla.
    may ibang picture ka yung sa behind the rear view mirror? di kasi masyado kita kung paano ginawa.
    Oct 2014
    #767
    To mount it to the rear view mirror:
    Bicycle stand + Switch Support/s + Adapter
    Oct 2014
    #768
    This one; but mounted using the suction type.
    Eto bro yung mounting nung SJ4000:
    Attachment 25123
    Right in front of the rear-view mirror para minimal obstruction. Yung wire though hindi ko na pinadaan sa A-pillar kasi maiksi.
    #769
    Quote Originally Posted by Sebastian Bach View Post
    Had it done at Jetcar Audio in Banawe. Took only 20 min, paid only 300 for labor and a fuse. They used the car charger that came with my SJ4000, yun yung ginamit na 12V to 5V converter. I bought that charger from Bettina's Gadgets for 200 I think.
    #770
    Quote Originally Posted by wewoy_romero View Post
    Here you go:
    Just used the supplied mounts of the SJ4000. Much better than suction cuz it doesn't fall off, and more importantly, doesn't ruin my tint.
    Apr 2006
    #771
    thanks sir. eto yung mount para sa bike? kuha ko na kung paano hehe
    #772
    Yup. The same mount you use to wrap around the handlebar, you can use on the rear view mirror's stalk.
    #773
    Here you go:
    any idea where can i buy the mount itself? try ko sa existing dvr ko.
    #774
    For GoPro mounts, marami sa OLX bro. Meron din sa CDR King.
    Aug 2006
    #775
    If you are talking about the bike mount, you may also get one from cdrking for 250 pesos. Kung sa glorietta 4, nasa gitna yan makapasok ng cdrking where technician is on your left
    Jun 2015
    #776
    Thanks man!
    #777
    ganito din sa akin, nilagyan ko lang ng cut out rubber from old bike interior dahil maliit yung kakapitan.
    Apr 2014
    #778
    Friendly advice for those who got the G1W/G1WH dashcams, try replacing your current suction cup with this rear mirror mount. More sturdy and won't fall-off kapag tirik ang kainitan ng araw plus no damage pa sa tint kung meron man. Though hindi sya nakatago sa likod ng rear mirror but stays exactly right below it. That for less than $3 sa eBay.
    #779
    Quote Originally Posted by tevilo View Post
    ok ba yung G1 sir?
    Wala ba local sellers niyan?
Blackbox DVR/Dashcam
