Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 65
    Oct 2009
    #41
    pwede kaya i-program to sa ibang alarm system? san kaya sya compatible. Spare na kasi to e, kung di ko magamit baka ibenta ko na lang.
    Jun 2007
    #42
    transporter2: i'm interested. pm me how much sell mo.
    #43
    - Lahat ba ng sasakyan pwedeng i-wire ang trunk release at remote window?
    - Kahit ba carb pwedeng remote start?
    Jun 2007
    #44
    - depends on the alarm installed if meron trunk release option.
    Kahit ba carb pwedeng remote start? -mas preferable yun mga automatic transmission.
    #45
    anong autopage ang pwedeng me trunk release?
    me addon component pa ba ang trunk release ng autopage?
    Jan 2010
    #46
    mga sir magakano ba yung autopage rf-420 at rf-320? tsaka along banawe din ba yung blue lazer? thanks!
    Apr 2009
    #47
    Had RF425 installed on my Everest in Blue Lazer yesterday. Cost me 6,200 less 5%. Had also rollup/rolldown window on the driver side installed (extra charge - mura lang). Dumayo pa ako. Magaling installer nila at pulido gumawa. Malinis ang wiring. If you want auto start you will need to purchase a separate module 1,800 yata. Sinadya ko talaga sila. Sulit ang punta ko. Best is morning nandoon na kayo.
    #48
    Mga bro, Meron ba tong manual override sa loob para kung nagloloko yung remote mo or nawalan ng battery ma disable mo yung alarm? Thanks.
    Jan 2008
    #49
    Quote Originally Posted by Cybie View Post
    yep, meron override 'button' un autopage 420/425 -- as long as you have the keys, you can enter the car using the keys (this will trigger the alarm) then disable the alarm via the override 'button'. syempre, medyo madidistract ka since tumutunog un alarm mo habang ngdidisable ka eh
    please confirm mga autopage peeps
    Feb 2005
    #50
    Magkano ang autopage 425 tapos wala pang central locking yung car? Magkano lahat TIA!
    #51
    mga sir, pag nagpainstall kaya ako ng car alarm sa Blue Lazer maaayos na din kaya nila yung sira sa front passenger side ko na lock? kasi di na gumagana yung Power Lock dun sa door ng front passenger side eh, aayusin din ba nila yun once na magkakabit sila ng car alarm or need ko pa ipaayos sa ibang place yung problem nung power lock ko?
    Feb 2005
    #52
    I'm sure kaya na nilang gawin yung power lock mo or papalitan nila ang actuator kung sira.
    Up ko lang question ko, magkano central locking at rf425. Pang Toyota Commuter.
    Feb 2005
    #53
    Di nagkakabit ng Central Locking pang Commuter ang BlueLazer may irerefer lang daw sila sakin na magkakabit. Alarm lang daw ikakabit nila.
    Feb 2007
    #54
    Quote Originally Posted by paulnvrt View Post
    Yes, it's correct. Similar to valet mode
    #55
    Also planning to change my alarm, badtrip kasi nawala ko remote and susi ng kotse ko , nag iisa nalang remote. yung locks bale pwede i delay pag lock after start ng engine for rf425?
    Feb 2010
    #56
    Fellow Tsikoteers, saan ba pwede magpainstall ng central lock for my nissan urvan? Yung shop sana na pulido gumawa at saka within banawe area lang sana or yung medyo malapit kay Blue Lazer. Hindi daw kasi nagiinstall ng central lock si blue lazer kaya kailangan ko muna magpainstall sa iba before ako magpakabit ng alarm sa kanila.
  17. #57
    Quote Originally Posted by blue_centrix View Post
    Kaya dapat ni Jameson yan. Hanapin mo sa FORCE budget alarm thread... Ikaw na lang hanap nang magandang power door lock set (actuators).
    Feb 2010
    #58
    Ok na car alarm ng nissan urvan ko. Got my central lock purchased and installed at goldcars in banawe, ok sila magkabit, maayos. Yung alarm ko is autopage rf320 c/o blue lazer. These are the additional features that i asked them to install on top of the standard features:
    1. Driver side priority - first press of disarm button will open the driver side only. 2nd press would be the remaining doors. Additional cost of P150 for the relay.
    2. Dome light - dome light will turn on upon press of disarm button. It also blinks on panic mode together with the turn signal lamps. Additional cost of P150 for the relay.
    3. Turn signal lamp confirmation - instead of the usual park light confirmation, i asked them to use the signal light para it would look like factory installed alarm. Additional cost of P100 pesos for the two diodes.
    Sobrang happy ako sa autopage. Highly recommended brand. Highly recommended din ang Goldcars for their service and most especially BLUE LAZER for having very competent technicians.
    #59
    Hello fellow Tsikoteers,
    Ask ko lang kung gaano kalayo ang range ng autopage? Naghahanap po kasi ako ng 100 meters or more (like viper).
    Oct 2009
    #60
    Quote Originally Posted by dvl View Post
    Sir mga 100meters kaya ng AutopageRF-425 in open space gamit ko yung LCD Remote pero di ko na gamit ngayon kaya benta ko na din.
    Check mo din sir kung may antenna yung module ng alarm, usually parang maliit na wire yun, mga 12inches ang haba, then gawan mo paraan para ma-expose, ganun kasi sa alarm ko ngayon pero iba brand.
Autopage RF425/420
