Results 211 to 220 of 231
- Dec 2002
- 2,335
October 28th, 2012 11:04 PM #211the only reason why thick ballasts are thick is because the ignitor is housed together with the main body of the ballasts. Thin ballasts have ignitors mounted separately. A good quality ballast, either thick or thin will last a long time and have a low failure rate.
October 29th, 2012 02:47 AM #213
October 31st, 2012 05:47 PM #214
before 2 set ang ballast meron ako, 1 pair is china na 55 watt ballast slim type...
after a couple of weeks, meh konting flickering sa start up... so pinalitan ko na lang agad..
2 pairrs thick ballast na nagamit ko before and hindi naman nagloko yung mga ballast so far..
pero siyempre as time goes by, there will improvements in terms of quality of the capacitors and other components inside the ballast
pero na observe ko even the OEM ones like Denso, matsushita, even the morimotos are thick in construction unlike the more common china type slim ballasts.. though denso calls their ballast slim pero parang malaki pa din eh..
- Aug 2007
- 425
November 1st, 2012 01:12 PM #215very informative thread.. although i kinda got lost in the technical explanation.. i just got a bnew sorento which has a low halogen projector fitted with h7 bulb and a hi halogen reflector. i'm planing to upgrde the low to hid. can simenw enlightne me on what i am to expect should i upgrsde... will it have the same quality as a retrofit projector. TIA
Sent from my AT100 using Tapatalk 2
November 1st, 2012 01:47 PM #216
- Aug 2007
- 425
November 1st, 2012 02:21 PM #217but will the hid/ halogen projector combo be better in terms of light output than the original halogen projector ?
November 1st, 2012 02:51 PM #218
I highly doubt sir... Kasi if your projectors are designed for halogen bulb pag nag hid ka, mas magmumukang intense lang yung color,, medyo scientific lang, pero iba kasi ang focal point ng halogen bulb versus sa hid bulb, therfore hindi mo talaga ma compare it to retrofit which specifically are made to utilize and maximize the light from the hid bulb...
November 1st, 2012 03:13 PM #219
November 1st, 2012 07:59 PM #220
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
