Results 1 to 7 of 7
February 20th, 2007 08:57 PM #1
Question lang... Malaki ba difference ng buga and kulay ng ilaw ng all weather 100/90 vs 130/90 na h4 bulbs?
Napundi kasi yung lowbeam nung isa kong headlight kanina, e medyo mahirap maghanap ng 130/90 na pamalit. I was thinking kung halatang iba ang wattage kapag 100/90 lang pinalit ko.
And kung may alam na rin kayong bilihan ng 130/90 na bulb, preferably around QC, paki post na rin.
Thanks po!
- Aug 2006
- 18
February 20th, 2007 09:11 PM #2Sir try nyo mo sa sm north or sm frvw. Infinity name ng shop. Nakabili na ako duon dati ng 130/100w na bulb. Meron din sila 170/110 n bulb.
February 21st, 2007 10:31 AM #4
Be careful. With wattages that high, you may end up melting your wiring harness.
February 21st, 2007 11:16 AM #5
and more often than not, they dont produce true wattage figures as claimed on the label. parang sales talk lang. just get a good set of all weather bulbs, upgrade your wires and harnesses, then install a relay. you'd notice a big difference in illumination
February 21st, 2007 11:40 AM #6
Three concerns:
1. Melting wiring harness
2. Melting plastic reflectors if your car has those instead of metal reflectors
3. Increased workload for alternator and possible shortened life of alternator and/or battery.
Note: aim them properly so you can prevent glare AND still see optimally (what's the use of increasing wattage if they're pointed in the wrong direction?)....
February 21st, 2007 11:48 AM #7
Thanks for the replies. I've been using Hella 130/90 all weather bulbs for the last few months, wala namang problema. I'm also using a high wattage harness na, with heavy duty fuse. Wala namang problema, napundi lang talaga.
It just doesn't feel right na papalitan ko ng 100/90 kung galing na ko sa 130/90.
so i looked under the two twist-beam cars i have here. wala talagang weld sa top and bottom. and...
Chery returns to PH
