Results 1,251 to 1,260 of 1387
- Dec 2013
- 146
December 19th, 2019 10:05 AM #1251G5-R hotspot malakas, G5-EX widespread beam pattern, G5-EXL pinakamalakas focus ng hotspot. Napanood ko lang sa youtube ni lightwerks. Natutuwa ako manood ng mga diy retrofit. Nag diy fog retrofit lang ako.
- Jun 2016
- 67
December 20th, 2019 02:52 PM #1252
December 22nd, 2019 11:40 AM #1253
Kung tama sinabi ni sir geronimo then get the g5-exl. Pero i would interchange the two since sabi ni sir geronimo, widespread beam pattern ng g5-ex. G5-exl for high beams since focused hotspot.
- Jun 2016
- 67
- Dec 2013
- 146
December 22nd, 2019 11:56 PM #1255G5-R G5-EX G5-EXL Projector Comparison + Lux Testing - YouTube
Post ko na lang din link dito. Kala mo yung simpleng upgrade ng hid masatisfied ka na dahil sa malaking improvement ng headlight output from halogen at led tapos meron pa pala levels ng hid upgrade. Depende pa sa projector lens, ballast at hid bulb.
Sa may fog hid separate switch yung fog high beam nyo o kasabay ng stock high beam?
- Oct 2019
- 19
- Oct 2019
- 19
December 24th, 2019 09:40 PM #1257
- Oct 2019
- 19
December 24th, 2019 09:44 PM #1258
Maganda sana po if ung G5-EXL ang inner projector nyo then G5-EX ang outer projector pero depende pa rin if mag-fit sa Forty nyo.
Though nakakita na ako na ang set up sa current Everest.. G5-EXL ang outer projector then G5-EX ang inner projector, maganda naman ang bato ng ilaw. Ninlagay ang G5-EXL sa outer part ng Everest kasi un lang ung way para ma-fit sa HL housing.
December 25th, 2019 08:23 PM #1259
Since I've replaced my Osram CBI D2S bulbs to Osram CBBs, I have no need for the old bulbs. PM me if anyone of you here is interested. Hehe
- Jun 2016
- 67
December 25th, 2019 10:31 PM #1260
high idle RPM at engine start
