Results 851 to 860 of 1387
- Mar 2018
- 263
May 29th, 2018 02:11 PM #852
Finished reading 86 pages. So tingin ko po magpapalagay ako kay redline stage 2 or 3 po.
Using '08 Rav4 stock projector vkool k14 windshield. Planning on getting an HID projector po, so meron po kaya na hindi naman maputing maputi? Like improving the all weather light ng stock like the HID po? farther, more width more definition po?
advises are very much appreciated po.
and also kahit luma na po ay very clear pa rin ung HL housing wala po moist.
I've experienced this on a camry with hid projectors and medyu mahirap nga siya lalo na malakas ulan and sa asphalt halos wala na makita. And parang mas mabilis po ata bumigay HID projectors? ung rav4 ko 116k pro ok pa rin HL and fogs. the camry was 09 and 64k odo pro bumigay na left HL niya.
May 29th, 2018 02:11 PM #853
Actually halos di mo differentiate yan just by looking at it kahit pag tabihin mo pa. You need a light meter for you to be able to know which one is more intense at a certain distance. Then there is also kung anong projector and ballast ang gamit. Between NHK, osram or philips, lifespan sila magkakatalo. Osram and Philips ay may malaking R&D so isa yan sa mga effect. Check mo D3 tech fb page may mga orig osram and philips hid sila. Or you can contact firedrake, nakita ko sa fb page nila meron na silang gen2 ng philips xvc1. I'm using the gen1 btw.
May 29th, 2018 02:26 PM #854
I'm a philips guy(not that there is anything wrong with osram). Isa sa mga gusto ko sa philips is yung totl nila ay di ganun ka puti compare sa same tier ng osram. Pero personal preference na lang yan. Ang famous sa sa osram na all weather bulb nils is the night breaker which is also too yellowish for me but then yung cbi and cbb nila is too white naman for me. Kaya philips yung binili ko dahil ang 85122 nila is almost oem color temp at 4300k at yung xv naman nila is not that white at 4800k lang.
If you want width famous ang mga oem spec projectors diyan and downside is that they are huge and if limited ang HL space sa loob di pwede. Di rin bolt on ang mga oem spec. But for 08 rav4 for malaki ata HL nyan so pasok kahit yung FX-R or the RX-350 projectors.
About sa moist lahat ng HL ma tendency magkaka moist kaya may mga vents ang HL assembly natin for that. Pero pag dating sa re-sealing ng HL after the mod install the installer has to ba capable and quality ang trabaho kaya mga known reputable shops is a better choice pag nag pagawa ka.
May 29th, 2018 03:09 PM #855
May 29th, 2018 03:48 PM #856
Ask mo na lang si angelo kung ano current bulbs ino-offer nya. Last time sa mid-level nya philips 85122 gamit at xv or cbi naman sa vip package nya. Alam ko may fx-r siya na projectors pero kung wala sa kanya at the moment mga hinahanap mo he can order it naman.
Yes not advisable na parati kang mag flash sa retro projector, it's not that masisira ka agad but its useless kasi. Kahit naka fast bright oem or aftermarket ballast ka pa you still need a couple of seconds for the bulb to reach its full intensity so by the time the bulb reach its full intensity baka lagpas na yung pinaflash mo na vehicle
I think you have more than enough space sa vehicle mo if you decide na oem spec projectors.
- May 2018
- 3
May 30th, 2018 04:53 PM #857
May 30th, 2018 06:44 PM #858
- 54,213
- Jun 2005
- 3,774
May 30th, 2018 10:12 PM #860
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
