Results 841 to 850 of 1387
March 21st, 2018 05:35 PM #841
Sa actual if you observe even the 4300k is still A bit whitish if compared to stock halogen bulbs at around 3800k. As you go higher kelvin ma notice mo na nagiging bluish white ang output at the same time you also loose contrast. Eto din ang rason if ma notice nyo na pag malapit ng ma sira or matagal na ang hid bulbs nyo ay mas maputi siya tignan kumapara nung bago pa.
Ang sagot sa tanong mo is, ano ba preference mo? Yung iba dito gusto nila cbi at 5500k dahil nga mas maputi ang effect nito kesa philips counterpart nya and mostly those guys live sa city and also ino-offset na lang nila yung buga ng cbi sa fog lamps nila. Me, kahit may fog lamps ako I prefer the 4800k of philips xv, not to white like cbi and not too yellow like the night breakers, another reason is taga probinsya ako and 95% asphalt na walang street lamp ang mga kalsada.
If you want a hue of yellow which is an all weather application go for osram nightbreakers at 4200k.
- Jun 2016
- 129
March 26th, 2018 12:57 AM #843
March 26th, 2018 06:14 AM #844
If di pinag tabi ang output ng philips85122 ko dati at 4300k and the xv c1 ko ngayun at 4800k, I wouldnt even know which is which. Same goes sa cbi and xv c1 unless magka tabi mga output shots nila. Pero yung sa 85122 ko dati after about 4yrs medyo na notice ko na difference.
Na prove ko rin ito sa trabaho ko. Meron akong mga flood lamps rated ar 400w these are metal halide bulbs almost similar if not thesame ang halide salts nila na gamit sa hid bulbs ng sasakyan natin but at a bigger scale lang. Pag bagong palit ko yan medyo maypag ka yellow ng konti but pag malapit na syang mapundi bluish white na ang output nya.
Sent from my SM-J730G using TapatalkLast edited by D3nb3r; March 26th, 2018 at 06:29 AM.
- Feb 2017
- 53
April 8th, 2018 01:22 PM #845
- Mar 2018
- 263
April 18th, 2018 06:22 PM #846Anybody tried to change h11 halogen to h11 led?
Sent from my ONEPLUS A3003 using Tapatalk
- Sep 2009
- 387
April 18th, 2018 08:54 PM #847
- Mar 2018
- 263
April 19th, 2018 09:45 PM #849
Nice output. The 6600 lumens might probably be true. Some manufacturer put big numbers on the packaging to increase profit. Pero in car headlight application dapat lux, not lumens ang basehan. There is a difference.
Just like in car audio, some manufacturer show max wattage which is useless, instead of presenting rms watts. But hey, most people wouldnt care if it's a lumens, lux, max wattage or rms watts anyway
- May 2018
- 3
May 29th, 2018 01:30 PM #850Good afternoon guys, nag pa retrofit ako recently and ang gamit na bulb ay NHK 4300K D2S 35W. Ask ko lang totoo bang night and day difference and NHK to OSRAM? And ask ko lang din, saan ako pwede bumili ng OSRAM or Philips na bulb san Metro manila? Kahit mas mahal pero yung sure Orig yung bulb? Thank you guys! = D
Because pinoy mentality. Not surprising.
