Results 361 to 370 of 717
December 27th, 2012 05:27 PM #361
mahal talaga sa Blade. nung naghahanap pa lang ako, sa Blade ang pinakamalapit na me new (or NOS) stocks kaso ang mahal nga. P2,500++ if i remember right. i can't bring myself to buy from there knowing na P1,200++ lang ito sa banawe/sgt. rivera.
so far, i'm a very satisfied owner of the Philips Xtreme Power. I chose this over the Vision based sa mga nabasa ko rin dito bago ako nakabili. mas maganda raw ang visible light output nung PXP. on my next change, baka i will try the Osram NB+. mas marami kasi ito sa market at comparable sa Philips na rin ang performance reviews.
December 27th, 2012 10:09 PM #362
Need inputs on which is the better option to go for my case.
I have CX9 which has stock projector halogen H11 for lowbeam; and halogen 9005 for highbeam. For me, lighting power is not sufficient for the low beam. So my requirement is to have more powerful lighting especially on lowbeam. So am thinking if it's better to:
1. Change H11 bulbs to Philips XV or Osram NB+;
2. Or go for H11 HID plug-and play;
3. Or go for complete HID retrofit
So which do you think is better for my requirement, and why. And pros and cons if any. Kindly share your opinions and experience on this.
Also, is it easy to DIY #1 or #2? Any special instructions?
Would appreciate. Thanks.
December 27th, 2012 10:35 PM #363
If budget is not an issue, go for complete retrofit. Quad projectors set up ka na. Parang tanghali na siguro niyan kahit gabi.
December 27th, 2012 11:19 PM #364
If you choose number 2 hindi rin gaano kalaki ang brightness na maidadagdag kasi your projector is designed for halogens. Yes walang glare pero ang projector na made for HID ay may wider and maybe more intense output. If budget permits go for a projector retrofit. Quad setup kung galit ka sa gabi hehe pero no need for quad dahil yung normal retrofit lang will suffice.
My friend has a Philips XV installed on his Pajero FM and estimated 80% output in terms of light intensity ang nadagdag nung XV, output also became a little wider.
December 27th, 2012 11:53 PM #365
Dun ako sa option 3 if you really have money to burn. Pero kahit di na quad set up. I still prefer yun may halogen high beam parin, parang spot light kasi yun tsaka mas effective ipang flash sa mga pasaway
December 27th, 2012 11:59 PM #366
December 28th, 2012 12:00 AM #367
December 28th, 2012 12:02 AM #368
December 28th, 2012 02:28 AM #369
No sir stock HLs lang. I just thought I'd give you an idea of the output of Philips XV on stock lighting hehe.
If you decide to go for retrofit, better to keep your HI beam stock para may pang flash ka as HIDs are not meant to be used as flashers (on and off), they will shorten the bulb's lifespan.
December 28th, 2012 04:09 PM #370
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
