Page 1 of 22 1234511 ... LastLast
Results 1 to 20 of 717
    Jun 2007
    New generation of the two most acclaimed and compaired Headlight bulbs....
    Has anyone used any of the two?
    I called one of the shops I know regarding the Philips Xtreme vision....and they said that the stocks will be coming in by the end of the month....
    Jul 2010
    saang shop po yan? how about yung NB plus?
    Up ko lang yung question.. saang shop makakabili ng Philips x-treme and how much po?
    Dec 2007
    Quote Originally Posted by wrcastro_ph View Post
    Sir regarding Philips Xreme-Vision, wala pa dito, pero makakabili kayo online sa powerbulbs.com. Kung Xtreme power, marami sa malls. meron rin ako na h4 for lesser price.
    Dec 2009
    alin ang mas malakas = osram all weather/philips xp 55/65 watts o ordinary na 90/100watts?
    Dec 2007
    *aeo62000,
    technically mas malakas ang 90/100w bulb. Pero subjective kasi ang pagiging "mas malakas" na headlight. Eto ang pros and cons sa mga choices mo:
    Osram All Seasons:
    Pros:
    A little Yellowish light, meaning more contrast pag bad weather.
    Malakas.
    Comes in 55/60w+30% more light, meron ring 80/100w.
    Cons:
    Hindi lahat gusto ng yellowish light.
    Higher wattage (80/100w) means upgraded wiring is recommended.
    Mid Priced (approx 400-500php per piece)
    Philips XP:
    Pros:
    stock wattage with +80% more light.
    no mods needed.
    well-focused.
    Cons:
    Shorter Lifespan compared to normal bulbs.
    Expensive (1.4k to 2.3k php per pair)r
    Lighting may not be bright compared to Hi-wattage bulbs (subjective).
    Normal 90/100w Bulbs:
    Pros:
    Generally Bright
    Cheap (other brands are sold around 200php per piece)
    Durable (if you stick with known brands)
    Cons:
    Needs upgraded wiring to be more effective.
    May damage plastic lenses.
    Not recommended by OEM.
    Please take note that lighting is very subjective. It's best to try out different bulbs on your own car and see what's best for you.
    Oct 2009
    kamusta NBreaker?
    Dec 2007
    Sir harold13, the NB's are considered one of the best bulbs, along with XP's, due to their power and focus while using stock wattage.
    Jan 2008
    Anyone here know where i can buy either of the two next-gen bulbs? May nakita ako kahapon sa Jet Aldo Car Accessories, 1.7k daw for X-treme Vision H7. Meron ba fakes nun? Prefer ko sana NB Plus pero wala ako mahanap. help! thanks!
    Jun 2007
    try mo dun sa abonifacio corner C3 tabi ng caltex yung specialty store talaga ng mga bombilya....pang bahay man o kahit san...
    just bought philips x-treme vision last month at Roadstar The Fort worth 1,800 for H7 pair.
    better than osram NB but I also want to try the new Osram NB plus.. pero wala pa yata dito sa Pinas.
    Quote Originally Posted by PareKoy View Post
    sir san po yang Jet Aldo Car Accesories? any update ng price for Philips
    xtreme vision for a Pair?
    magkano po kay Osram nightbreaker Plus and saang store?
    Sa Blade sa MOA meron netong Philips Xtreme Vision, H4 siya for 2.5k a pair...
    Philips X-treme Power user here satisfied naman ako sa gabi.
    Dec 2018
    philips e-treme
    Jan 2019
    Feedback naman po usng Osram NB or x-treme vision during heavy rain.
    Apr 2009
    Quote Originally Posted by ramirv View Post
    They are brighter than stock bulbs but not whiter than LED/HID bulbs. They are ok in inclement weather. BUT, like with any other form of bulb, if your windshield tint is dark you know the answer. It also relatively dependent on your visual acuity...
    Jul 2010
    Pwede po ba ang PXV sa 09 fortuner for headlamps and fogs.. planning to replace the oem bulbs ang hina kasi ng output..
    Quote Originally Posted by adslim_15 View Post
    ang nakita ko po kanina sa Autoline sir H7 at H4 na bulbs. I don't know ano po ang sa fortuner, if isa sya sa mga yon, pwede po sya. di ko po kase kabisado mga bulbs, basta sa jazz ko po kase H4.
    Jul 2010
    ic, h11 for low beam, hb3 for high, and hb4 sa fogs..maganda sana ang PXV kasi plug and play lang and maganda tlga performance ang taas ng reach..ive use it sa dmax h4 rin..
Philips X-Treme Vision Vs. Osram Night Breaker Plus
