Results 101 to 110 of 717
August 27th, 2011 09:36 AM #102
August 27th, 2011 11:33 AM #104
sorry for dumb question...one pair lang ba ang kelangan ireplace or bilhin kpag maguupgrade from stock to philips xv? will the pair of bulbs already cover the high and low beam? thanks!
August 27th, 2011 02:26 PM #106
- Jul 2009
- 2,618
August 28th, 2011 12:07 AM #108H7 philips extreme vision bili ko noon sa blade 2400 over 2yrs ago.
just this week napundi na yung isa I replaced with the same extreme vision uli 1800 sa roadstar alabang.
HTH
August 28th, 2011 06:05 AM #109
mga paps, nakabit na yung philips xv sa honda jazz ko kanina... 1500 sa cartronics... then nung pauwi na ko ngayon lang gabi, pansin ko parang may mali... parang mas nahirapan yung visibility ko sa night drive vs the stock halogens... to the point na muntik na kong bumangga jeep naka stop pla, as in di ko sya nakita nung malayo, nung malipit na lang sya biglang narealize na jeep pla sya...never ko tong naexperience to sa stock...
naisip ko baka may mali sa installation...does this happen? may kelangan pa bang i-adjust...is there something to do with the cutoff? parang di ganun ka sharp or definite yung cutoff or line nung ilaw...tska parang ang baba nung buga...kse napansin ko dina di ko kaagad mabasa yung plate number nung katapat kong kotse unless tutok ko na sya...theses are my observations at low beam. i was supposed to capture everything in video pero na low bat na cel ko...
naobserve din oaka to ng passenger ko, sabi nya parang di kaagad makita yung kotse sa malayo, mga 3 to 4 cars away parang shadow/silouhette pa din...
then kapag hi beam nman, maliwanag naman sya, malakas yung buga..to the point na nakakasilaw yung light reflection sa kotse sa harapan ko...yun lang sa low beam lang parang may mali...
then while driving at night, biglang bumuhos yung malakas na ulan...wala na, as in kelangan ko nang magslow down almost to a near stop kse puro liwag lang yung nakikita ko na maputi...
this is just very weird considering clear tints na ko...
haay...pano kaya to?
Sa 12K na gamit hindi pa kailangan. Ako sa typical 40K pa din nasanay change ATF at gear oil. ...
Ford Everest 2015
