Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 101
    #41
    better stick to stock colored bulbs
    yung mga H4, H7, etc... codes ata yan ng gma bulbs eh... conventionally, mga euro cars ang gumagamit ng mga H7 bulbs. ang madalas dito sa atin, gamit ay H4.
    sa galant ko, H4 para sa headlights (dim), H1 para sa high beam, and H3 para sa foglights.
    bulb/fog light application chart guide:
    http://www.import-store.com/bulbapp_guide.htm
    An H4 bulb is also referred to as a 9003 or an HB2
    A 9004 bulb is also referred to as an HB1
    A 9005 bulb is also referred to as an HB3
    A 9006 bulb is also referred to as an HB4
    A 9007 bulb is also referred to as an HB5
    HTH :mrgreen:
    #42
    Quote Originally Posted by ssaloon
    HTH :mrgreen:
    ano diff ng (H4)dim sa (H1)high beam? seperate bulbs ba yan?
    ang alam ko kasi one type of bulb lang gamit natin keso sa highbeam or lowbeam...
    #43
    sa galant kasi, hiwalay ang bulb ng dim at bright. tingnan mo yung pic sa signature ko, 4 yung pangreflect ng ilaw dba?
    so bale 4 bulbs gamit ko, 6 kung kasama fog lamps.
    #44
    ah ic! gets ko na! diba sa altis ganyan din? bale 4 gamit pang headlights...
    so for ordinary cars... like mine xwind... H4 lang gagamitin namin...
    thanks ssaloon!
    another question... pwede mo ba rin ba gamitin H4 sa hibeam mo? or H1 sa lowbeam mo? which is brighter H4 or H1? gulo na ba? ... ndi kita niloloko ah... gusto ko lang malaman kung baket ganon ... tenks!
    #45
    4 headlight patterns usually use H4 and H1 bulbs
    While the standard 2 headlight pattern uses H4 bulb only.
    #46
    Quote Originally Posted by dieselNUBI
    H4 are used on dim and bright modes while H1 are only used for hi-beams. Kung tinatanong mo kung anong mas malinaw sa H4 or H1 it all depends on the bulb wattage you are using.
    No you cannot fit an H1 into an H4 housing neither vice versa. They have different mounts and wirings.
    Just my .002 :D
    #47
    Quote Originally Posted by Ungas
    Just my .002 :D
    thank you!
    i learned something new again from tsikot.com!
    #48
    Welcome.
    #49
    wait, ako naman ang naconfuse. :oops:
    you say you have both H4 and H1 e d ba H4 meron ng hi beam yon? so pag nag high beam ka 2 bulbs ang gagana? both your H4 and H1? tama po ba?
    d ba mas mahirap tingnan yon esp pag d pareha wattage and/or color ng bulbs mo? like if you get super whites sa H4 then yung H1 mo yellow pa din.
    #50
    Quote Originally Posted by boybitz
    Yes H4 operates on high and low beams.
    Dim = H4 lights on, H1 off.
    Bright H4 on, H1 on.
    Brighter colored bulbs will prevail, with your sample, Mawawalan ka ng super whites pag gumana ang colored bulbs. It will render your super whites useless.
    Kaya dapat pag magpapalit ka ng bulb, pare-pareho lahat ng bulb shade ang gamitin mo. Kundi masasayang lang ang super whites kung may kasamang ibang kulay.
    #51
    ako naman ulet...
    what type of bulbs do they use para sa foglights ng xwind...
    i know that these are not really "foglights"... ika nga pampa ganda lang...
    im thinking of replacing them also with vision plus... or maybe philips all weather... para maliwanag talaga ang daan ko!!!
    #52
    malamang sa fog lights H3 yan... pag pinatingnan mo naman sa shop na bibilhan mo ng bulbs, malalaman naman nila eh...
    pag magtataas ka ng wattage tapos paparelay ka, ipare-aim mo na rin yung headlights mo para di nakakasilaw sa kasalubong motorista. road courtesy lang. :D
    #53
    un foglights ko naman naka faced down na eh. range nya maybe 3ft lang...
    Mar 2003
    #54
    ok ba kahit sa ulan yung vision plus?
    Dec 2002
    #55
    Quote Originally Posted by RC-V
    nakalagay sa bulb mo if what type sya. like my stock bulb w/c is osram h4. are you the one who is goin' to remove and install it? madali lang naman e. i guess h4 bulb mo kasi its not naman a projector type.
    osram h4 bulbs sa crv? ordinary ones or the +50%?
    ordinary ones, i changed the osram to visionplus and cld really see the difference when drivin' at night.my park light i changed it w/ polarg super white bulbs.
    Dec 2002
    #56
    Quote Originally Posted by redefine
    yup ok sya compared w/ your stock bulbs.
    #57
    is there really a big difference? kasi napapa second thoughts ako eh kung sulit ang 900++ bucks ko...
    #58
    balak ko kasi vision plus then change my parklight to orange ones...
    Dec 2002
    #59
    last yr it was only 800 introductory price ata. now 950 from a shop i inquired. maganda sana if you have a friend na naka visionplus, for you to see the difference of a visionplus compared w/ your stock bulbs.
    Dec 2002
    #60
    before kasi i did plan of replacing my foglight bulbs to visionplus, the shop told me that there's no visionplus bulb type yet available for the foglight. ask nalang sa shop for recommendations.
Philips Blue Vision VS. Vision Plus
