Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 101
    #21
    tumingin ako kanina sa isang shop dito sa amin, P995 ang isang pair ng vision plus. tapos yung diamaster nasa P1450.00. nakalagay sa packaging ng diamaster 55/60w --> 100/110w. ok kaya itong diamaster?
    Signature
    #22
    diamaster gamit ko dati... just wanted to get ur comments. ang lakas tlga ng ilaw na yan lalo na pag nagpakabit ka ng relay!
    pero napundi na yung isang bulb ko after 2.5 yrs of use...
    #23
    e36speeder, thanks sa reply ang mahal pala sa pwerbulbs.com
    sir boybi, sa metro manila ba iyang Php 995/pair ng vision plus?
    #24
    chieffy, dito po yan sa Tarlac. btw, nice meeting you pala the other day :D
    Signature
    #25
    OT:
    ehehe...Tarlac pa pala...pagpunta namin ng Dagupan sa summer kayo naman ang bibisitahin namin sir boybi Kamusta naman sir yung Nomad n'yo?
    #26
    Quote Originally Posted by chieffy
    OT:
    sure! txt mo lang ako.
    ganda nung nomad! baka i-trim ko pa yung sa trooper and patrol, medyo malapad yung sa harap.
    Signature
    Dec 2002
    #27
    i bought a set of visionplus for my ride last oct it cost 800/pair the last i went sa shop 950/pair. you cld also settle for osram.
  8. #28
    meron bang H4B na size ng Philips Vision Plus?meron bang H4B na size ng Philips Vision Plus?
    #29
    how about the headlights of the Xwind ?
    feeling ko kasi mahina eh. im thinking of replacing them with brighter ones. ayaw ko naman ng white. will philips vision plus help me? do i need relay or ballast with this?
    #30
    o nga pala.
    what does H4b / H7 means??
    #31
    san makakabili nyan? pundi na bulb ng crv ko eh...
    thanks!!
    #32
    sabi sa power bulbs "Optimises colour temperature to give deep white light"
    so does this mean na white lights sya? dont like white lights that much. still prefer ordinary color...
    so what type bulb should i use? (for xwind)sabi sa power bulbs "Optimises colour temperature to give deep white light"
    Dec 2002
    #33
    for the visionplus you juz replace your stock bulb no need for relays and ballast. its brighter than the stock but not white color like those other cars you see on the road. for me visionplus is the best replacement for stock bulbs. i suggest you buy visonplus, its not white, its like the ordinary color but much brighter.
    H4b/ H7 types ng bulb, my ride visonplus na H4.
    #34
    tanong ko lang ulit: ano difference ng philips vision plus sa philips diamaster?
    Signature
    #35
    great! i still prefer stock color bulbs than white ones...
    my question is: whats the diff between H4 / H7? what should i use for xwind?
    para bibili na ako bukas! xcited na ako to try it at night!
    #36
    nabasa ko sa powerbulbs...
    pag low beam kelangan ko. i use H1
    pag main beam, use H4
    ano mga to?
    Dec 2002
    #37
    nakalagay sa bulb mo if what type sya. like my stock bulb w/c is osram h4. are you the one who is goin' to remove and install it? madali lang naman e. i guess h4 bulb mo kasi its not naman a projector type.
    #38
    Quote Originally Posted by RC-V
    osram h4 bulbs sa crv? ordinary ones or the +50%?
    #39
    I was able to test my Philips Vision Plus one rainy night a few weeks ago... i was in front of an intersection waiting for the green light with an "H" car on my right side, you can clearly see the difference ng headlight beam namin on the wet road - talagang 50% brighter and it "cuts" thru the rain with its amber light (not white). Then he took off and all I was able to see was his tail lights... naiwan ako.... ehehehe. :lol:
  20. #40
    diba mas ok sa tag ulan yung amber/yellow light than the white ones? I'm currently using Raybrig na white eh, pero parang mahina nga sya, lalo na tinted din harap ng car ko.
Philips Blue Vision VS. Vision Plus
