Results 11 to 17 of 17
June 10th, 2011 09:13 PM #11
if you open your HL, the original sealant will be enough to seal it back.
June 11th, 2011 11:11 AM #12
san ko po ilalagay ang sealant pagitan ng lense and the housing? , pag ba lininis ko ng joy ung chrome hindi mangingitim? thanks for the replies!! TIA :D
November 22nd, 2011 06:39 PM #13
^ same question.
is this applicable to fog lights too (ray brig/stanley)?
parang hirap baklasin iyong assembly
November 29th, 2011 09:48 AM #14
Another way to clean the headlights, without having to disassemble the lens from the housing, which i learned from Glennster and did to our AE111 and Accord before:
1. Remove headlight assembly.
2. Flush/rinse with water and some detergent inside.
3. Drain soapy water and leave just enough to cover the lens when it's facing down.
4. Add cotton balls inside the housing and move it around inside the headlamp assembly (with some water/soap left), touching the lens and reflector.
5. Drain the water with the cotton balls.
6. Repeat if needed.
7. Blow dry the headlight assembly and sun dry for a day at the least.
December 2nd, 2011 09:06 AM #15
August 4th, 2013 10:27 AM #16
:help!:
^ you think this whole procedure will also work for tail lights too?
my fd's rear tail lights recently developed this recurring moisture problem in it and i so decided to buy a brand new set of oem gaskets for it. but before replacing those old worn out gaskets i'm thinking of cleaning them tail lights first before reinstalling them. so i'm wondering if the procedure outlined by bro theveed before won't do any damage to the tail lights assembly
August 13th, 2013 05:07 PM #17
Xiaomi E-Car
