Results 11 to 15 of 15
- Dec 2002
- 2,335
February 12th, 2013 12:28 PM #11sterling??? first time I heard about this brand. Meron mga times mali and filament position sa bulb so yung focal position sa HL mali din causing discrepancies sa output. HB3 and HB4 lang ang totoong HIR bulbs. All the others are copies and you can get bulb qualities na ganyan. If you really want HIR bulbs then get Philips kaya lang walang H7 sila, HB3 and HB4 lang.
chik: baka naman lumang bulb yung comparison. Kung luma na talaga yung bulb and kabitan mo ng XV, meron ngang difference. Yung pic posted is a nice stock Philips bulbs na standard quality vs. XV.
- Aug 2011
- 171
February 12th, 2013 12:45 PM #12*garyq
thanks for the good info. Well, parang I noticed nga naparang hindi nakasentro or perpendicular yung bulb itself sa base by a certain degrees. Not sure if ganun na from factory or baka dahil sa shipping and handling. Nakabalot lang ng circular styrofoam yung bulb sa loob ng box eh. Not much protection sa wiggle. My eyes could be deceiving me though.
I am waiting for the seller's input on this as well.
- Aug 2011
- 171
February 13th, 2013 03:42 PM #13May possibility kaya na na damage ko yung bulbs during the installation? First time ko kasi mag-install. Di ko naman hinawakan yung bubog na bulbs. Kaso medyo nangangatal kamay ko nung ipinapasok ko yung bulbs sa butas. Pero yung sa 2nd bulb, swabe na kasi nawala na kaba. hahaha. Kaso yun nga, pareho pa rin na sabog ang ilaw. Lalo wala makita pag gabi.
February 13th, 2013 04:39 PM #14
- Dec 2002
- 2,335
February 13th, 2013 11:05 PM #15Yes meron naman improvement. As mentioned, if you compare it to a new Philips or Osram bulb na standard quality, I would say mga 10-20% based on actual output and measurements on my light meter. It's a good first step if you want to improve lighting and I have these bulbs in stock with installation and alignment. Yes plug and play yan but you need to check your alignment. In terms of load sa circuit ng oto, same 55w.
high idle RPM at engine start
