Page 1 of 2 12 LastLast
Results 1 to 10 of 2382
    pcalday: sir anong type yung headlight mo? meron kasing Frontier na hindi pa clear lens yung headlights and I've seen 2001 units na clear lens na, yung walang lines sa harap. You can post a picture or post a link na pareho nung oto mo para I can check it out first.
    Aug 2012
    Hello Sir GaryQ,
    Just recently visited your site and I saw that S30 na yung latest and best projector you have right now. I remembered before na A3.0 was your best. Could you share the difference in terms of output?
    Thanks!
    giqz
  3. #3
    better shield design, sharper cutoff and thicker middle intensity.
    Jul 2004
    *blackhowling: nice adventure you have there with gary's retrofit. Pa-detail nalang panalo na yan!
    Apr 2012
    Quote Originally Posted by garyq View Post
    Sir Gary, na email ko na yun pictures.
    hello po sa lahat! bago ko lang nalaman na mali pala yung pag ugrade ko to hid kit since i need a projector headlight pala. I have a hilux 2009. Magagamit ko pa ba yung hid kit ko na nabili if projector headlight nalng ang bilihin ko? or mas better if pa retrofit nalang? thanks po sa inyong tulong.
  7. #7
    Quote Originally Posted by mjdg View Post
    You need projectors na maayos ang output. Dont get those whole assembly na naka projector na coz una, halogen projectors naka kabit dun, second hindi maganda output ng projectors na yun. If you really want to get a decent setup, use your stock headlamps and retrofit a good projector there. Pwede pa gamitin yung ballasts nung HID mo. I can guarantee you that a good retrofit will be better than those headlamp assembly na naka projector na.
  8. #8
    t'was a busy week.
    Interesting project as the customer wanted to retrofit on a projector type headlamp na aftermarket. So this is a stage3 retrofit on an aftermarket HL (perfect fit btw) plus fog projector retrofit On a Premium Hyundai Tucson gas
    Aug 2011
    Sir gary, question po how about the lightning output if we retrofit? Mas malinaw po ito compare sa stock projector like in montero? I notice na mahina buga ng ilaw kahit hid pa sa montero. Pag stock halogen naman sabog ang ilaw. Thanks
    Apr 2010
    Quote Originally Posted by Tj_abs View Post
    guaranteed mas maganda output and mas malakas bro. asked Sir Gary the same question before my retrofit and as he said, mas instense and mas malakas talaga. worth every cent!
HID Projector Retrofits by garyq
