Page 1 of 4 1234 LastLast
Results 1 to 20 of 69
    Jun 2005
    i would like to find out how the projector headlights, with its frosted lense, is brighter than the clear glass headlights? most of the cars coming out now are projector type...
    it might be that theyre already equipped with HIDs or a better halogen bulb imho
    i think it could have something to do with the magnifying glass effect.. im not really sure,, but it looks like that to me... jst my thoughts...
    Aug 2005
    when I switch to projecter type mas maganda ang liwanag nya compare sa glass type.. maganda din lagyan ng pure HID or philips halogen.
    Jun 2007
    Mas maliwanag ba sa regular headlights? mas ok ba kung may angel eyes?
    Aug 2005
    basta sharper ang projector type. parang spotlight.. pero depende parin yan sa bulb.. partner ang projector and normal headlight kaya maganda sila sa gabi.
    IMO, same cla ng bright pero different category .
    Jun 2006
    ritek: ok lang angel eyes kung naka BMW ka. pag hinde, parang TH ang dating e. pero depende sa'yo yun.
    Aug 2005
    Quote Originally Posted by Horsepower View Post
    yeah tipindani talaga yan sa gusto mo... you must not equate projector lamps to bmw cars only as you can see below:
    Projector Headlight
    When driving, what you can’t see and all those that can’t see you can be fatal and dangerous. That’s the main reason why almost all vehicles come with various sets of vehicle lights. The pair of light that’s typically installed in front of the vehicle is called headlights. These are lamps designed to illuminate the road ahead while driving in poorly lit areas or during periods of low visibility, particularly at night. Headlights are one of the earliest safety features mounted in the vehicle.
    Most headlights today are electrically operated and are required to emit a low or a high beam. High beam headlights give off beam that’s straight ahead to maximize seeing distance, but they usually send out too much glare and cause back dazzle brought by the reflection from rain, fog and snow. Low beams, on the other hand, controls the light that goes upward and reroute most of their illumination downward and either rightward or leftward. This is aimed to deliver safe and excellent forward visibility without too much glare or backdazzle.
    Headlights come in many types. Xenon headlights, HID headlights, Euro lights, halogen headlamps and projector headlights are among others. Replacing your existing vehicle headlights with projector headlights is among the great ways to enhance the car’s façade. Not only do they look good, projector headlights also give improved night visibility because of the brighter beam they produce and the wavelength of colors they give off. Projector headlights are offered in chrome, blue, black, red and other colors and are crafted to look so sleek that they are often mistaken as though they were customized.
    To give you a clear view, projector headlights is a type of headlight that gives out a stronger beam to light a more focused area with very accurate light dispersion and less scatter loss. Its design works like a slide projector and it allows you to see what you need to see sooner and more vividly. In projector headlights, a filament is positioned at one focus of an elliptical and a condenser lens is placed in front of the lamp. At the image plane, just between the lens and the reflector, a shade can be found and the projection at the top edge of this shade is the one that gives the low-beam cutoff.
    Purchasing the right projector headlight is very significant whether you’re planning to customize your truck, SUV or car or you want to enhance its driving safety. For a monochromatic and more attractive appearance, there are also taillights that are made to compliment your projector headlights. Should you want to customize your vehicle lights or you just need a replacement headlight, the best choice is projector headlights. Projector headlights are perfect for your restyling or customization job. Aside from their slick style, projector headlights are also easy to install. So if you wish for a car that really stands out from the crowd, update its style especially its front fascia using finely-designed projector headlights.
    from: http://www.partstrain.com/ShopByDepa...ctor_Headlight
    Apr 2006
    umm sorry for sounding ignorant, how do you quickly distinguish kung projector or hindi? yun ba yung may nakaharang dun sa bulb ng headlight? yun kasi napapansin ko sa mga headlights ng sasakyan. yung iba, yung bulb na agad, yung iba, meron yung parang nakaharang. also, does it have to do something with the lens? yung iba kasi parang clear, yung iba naman may mga lines.
    Sep 2004
    ^^^ Yung sinasabi mong nakaharang sa headlamp bulb na parang umbrella is not the projector type. This can be found in the 1997 Honda Accord and 1999 Nissan Sentra, among many others. Don't know what it's called though.
    Yung projector type is parang may lens na bilog sa loob mismo ng headlamp assembly.
    parang light diffuser yun eh.
    Jun 2004
    Pictures please...nais ko din masigurado itong mga klase ng ilaw na ito.
    projectors at the left, reflectors at the right
    projector lenses are dome shaped.
    most if not all have metal cutoffs inside..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Jun 2007
    Pwede ba lagyan ng Philips vision or mas mataas na wattage ang projector lights? anong recommendation nyo?
    imo, it can withstand higher wattage halogen bulbs since glass yung lens and solid na alloy yung case.
    Sep 2005
    Quote Originally Posted by finchy
    I think you misread Horepower's post. He didn't refer to projector lights ... but rather, angel eyes like these:
    (BTW, projector yung nasa right)
    ritek - Pang-porma lang ang angel eyes. Sabay lang sindi niyan sa clearance/parking lights like the pic above (low and hi beams off).
  17. #17
    dati naaaliw ko sa angel eyes na yan-->may devil eye naman lumabas-->instead of halos, 1 continious led around the housing naman ang racket...
    noon, wala kong tiwala sa projector( kasi wala kong experience sa projector) kaya i prefered to get the rectangular light-delica over the newer projector type lights delica.. ok din pala ang buga ng ilaw ng projectors, mostly used as low beam siya and perfect daw for HID or xenon upgrade, unlike most reflector type.. ut ther are reflector-type that are designed forHID most are factory installed, not aftermarket.
    Aug 2005
    those BMW angel eyes look are the same concept with the projector type headlamps. mostly angel eyes are more expensive than our ordinary headlamps.
    the only thing is the auto companies adopted this kind of headlights because of its safety advantage at night..it doesn't matter if left/right projector lens .. they are all projectors.. the poster asked which is better from the two.. dont have to say its just a porma thing.
    Jun 2005
    wow, thanks for all the replies guys.. keep your comments coming..
    Sep 2005
    Quote Originally Posted by finchy18 View Post
    Medyo OT na, so please forgive me.
    To be honest, I don't see why cars with angel eyes are safer than cars without it. Can you please explain it? After all, those halos don't help with road illumination at night. Whatever bulb is used, be it incandescent, LED or CCFL, the light is supposed to be diffused around the halo ... and not beamed towards the road. So you may have to forgive me if I don't see it in the same concept as projector headlights.
    Having said that, I would like to hear from anybody with a car fitted with angel eyes and actually state that it helps the headlamps with road illumination - which is the point in the discussion, right?
Projector Headlights - how is it better
