Just turn the screws behind the headlight assembly. The lowbeam and highbeam are adjusted at the same time. One screw adjusts the left-right and the other is the up-down position.
I have a problem.. san bah talaga yon headlight adjust ng ae111? yong bah screw na patayu? hindi kasi ma adjust kahit iniko kuna.. pangit ang beaming ko ngayun.. argg
d ko rin alam san ung screw mismo, screw ba siya as in screw talaga o kasi may nakita ako dun naka paside na may ipin kaso iniikot ko using screwdriver e hindi naman na-aadjust ung ilaw.
tago ung screw niyan usually malapit sa grill at face it on a wall para pantay dont forget to check the brights i tried to adjust once but the bright fucntion became useless kasi sabog pag naka bright.
If you can't find a crew popping up the headlight assy., you may try to check the top of the headlight assy. for holes with crown-like rotators. Tusukin mo lang ng philips na screwdriver to rotate. Normally two crown-like rotators yun per assy. Isa for up/down adjustments, and the other for left/right... IIRC that is.
