Results 1 to 9 of 9
- Sep 2004
- 95
July 25th, 2006 05:35 PM #2
usually, may screw sa socket ng headlight. clockwise to raise the headlight, counter to lower. diba isa lang ang bulb ng high-low ng AE111?
July 25th, 2006 05:39 PM #3
Just turn the screws behind the headlight assembly. The lowbeam and highbeam are adjusted at the same time. One screw adjusts the left-right and the other is the up-down position.
July 25th, 2006 06:23 PM #4
park mo sa flat surface then start mo i-adjust by way of screw. mayroong High and Low; Left and Right. damay na high beam dun.
Toyota is my choice
- Aug 2005
- 2,063
July 25th, 2006 11:28 PM #5sir pahirit ko nalng tong saking..
I have a problem.. san bah talaga yon headlight adjust ng ae111? yong bah screw na patayu? hindi kasi ma adjust kahit iniko kuna.. pangit ang beaming ko ngayun.. argg
- Sep 2004
- 95
July 27th, 2006 01:40 PM #6d ko rin alam san ung screw mismo, screw ba siya as in screw talaga o kasi may nakita ako dun naka paside na may ipin kaso iniikot ko using screwdriver e hindi naman na-aadjust ung ilaw.
August 15th, 2006 09:06 AM #7
tago ung screw niyan usually malapit sa grill at face it on a wall para pantay dont forget to check the brights i tried to adjust once but the bright fucntion became useless kasi sabog pag naka bright.
August 15th, 2006 10:00 AM #8
If you can't find a crew popping up the headlight assy., you may try to check the top of the headlight assy. for holes with crown-like rotators. Tusukin mo lang ng philips na screwdriver to rotate. Normally two crown-like rotators yun per assy. Isa for up/down adjustments, and the other for left/right... IIRC that is.
Toyota is my choice
- Aug 2005
- 2,063
August 15th, 2006 08:33 PM #9kay I really hate na ma bump ang kotse sa haripan ng headlighs kc ang hirap eh align eh..
Xiaomi E-Car
