Results 1 to 5 of 5
- May 2012
- 37
September 16th, 2013 12:25 AM #1Kelangan ko po ng tulong nyo, high beam no problem, i already checked the bulb no problem, pero may time na walang low beam, bumabalik naman paminsan minsan, anu po kelangan icheck? Tia
September 16th, 2013 12:31 AM #2
Check the column switch or the headlamp relay. I have broken both. Hehe.
- Dec 2002
- 2,335
September 16th, 2013 11:37 AM #3Locate underdash fuse ng LO beams. remove and check terminals, clean if needed. Install turn ON the LO. sa engine bay galaw galawin mo yung H4 socket baka meron loose connection, kung meron palit H4 socket. Pa crimp mo wag dugtong
September 16th, 2013 12:36 PM #4
Ganito din issue nung sa akin eh. Pag wala yung low beam, nag hhigh beam lang ako tapos bumabalik na. Minsan ginagalaw galaw yung socket. Pag ganun ibig sabihin nagkukupal (green thing) na yung loob ng bulb socket or yung mismong connection ng bulbs mo. Try mo gamitan ng sandpaper. If anything fails, try changing the sockets or bulbs.
- May 2012
- 37
September 16th, 2013 10:53 PM #5Chineck ko sya with multi-tester, walang connection yung ground ng low beam pero may ground sya kpag high beam, bkit kaya magkaibang connection pa sila, anyway saan ko po kaya makikita yung dugtungan ng groundwires. Salamat po
the winner is selling it :twak2: 350k daw i already messaged him haha. it's just a free car so i'm...
Bestune Pony mini EV
