Page 1 of 2 12 LastLast
Results 1 to 10 of 25
    Jan 2017
    Any shop would you recommend for headlight cleaning and restoration?
    Quote Originally Posted by Kimchijiji View Post
    i tried to DIY, but i forgot to apply anti-oxidation protective layer afterward. the finish degraded fast.
    if i may,
    if a replacement is easily available and cheap enough, go for it na lang.
    it's more long-lasting.
    May 2018
    Napansin ko lang its the headlights that usually oxidize, but the tailights are more resistant.
    Pag shop, I think they just use rubbing compound & buffing wheel on the lenses, or DIY kit lang din (see below). If you don't apply sealant afterwards maninilaw nga lang ulit.
    Nag restore ako ng headlight of one of our 13 year old cars using a DIY kit. Best results are achieved using kits with a polish separate from the sealant, rather than 2 in 1 products na restorer/sealant. Depende sa degree ng oxidation (grabe yung sa amin- neglected nung gumagamit) the lenses will clear up, but it won't be the same as yung crystal clear ng brand new. Tumatagal naman as long as you re-apply the sealant at regular intervals like wax (monthly works fine in our case).
    I omit mentioning brands if possible, pero marami ka makikita sa DIY hardware or car accessory shops, so if nagtitipid ka, prices are around (300-700) for a kit. It won't take an hour of your time to fix.
    If you buy new lenses naman, waxing the headlights along with the body helps delay oxidation din.
    Sep 2018
    Quote Originally Posted by SoleusBB View Post
    Thanks for sharing these information! Sobrang helpful to most motorist. Will check sa DIY hardware malapit sa area ko! I'll try this for sure! Thank you
    Mar 2004
    Remember to apply UV protection sealant after polishing the headlights ...
    Oct 2009
    what uv sealants are readily available? i was thinking of having it sprayed with automotive clear coat thats uv resistant. anyone tried this?
    Mar 2018
    Quote Originally Posted by battouter View Post
    up for this... nakikita ko dito eh yung meguiars headlight coating kaso avail ba ito sa local market like ACE hardware?
    Aug 2017
    Try this...
    Amazon.com: Rust-Oleum 249117 Painter's Touch Multi Purpose Spray Paint, 12-Ounce, Clear: Home Improvement
    Mar 2004
    CRYSTAL GUARD™ | Halden Galway International Corporation
    The Turtle kit was complete w/ sealant. Worked well w/ minimal elbow grease. Let's see how long they retain the clarity.
Headight cleaning shop suggestion
