I'm using generic mini H1 then 55w ballast, ok naman. Best decission para saken kesa mag mount ng pair of fogs ... hopefully no issues sya. So far so good :D
Sent from my GT-I9300 using Tsikot Forums mobile app
^kanino kayo nagpa install sir? and please post some output pics?thanks!
*sirbossr,
may nabanggit na seller/installer a few pages back. he's in sulit.com ata. paolo something hehehe planning to get a unit from him also if my budget permits.
D.i.y. install lang
Yung low beam sa pic dark yung sa baba, pero its not covered ng line of sight from the cabin since mataas yung auto ko. Sa labas ko kinunan ng shot since cam fone lang gamit ko. Its not perfect maybe due to my first time to install. But hey at 5.2k + d.i.y. skills i cant complain... hehehe
Take note yellow po ang street lights dyan... and i'm using 4300k light color
lately nabawasan na yung mga gumagamit ng HID sa reflector housings...
pansin ko lang...
maybe na realize na ng drivers na mas madilim ang HID na nilagay sa reflector housing versus stock halogens.
pero still kahit mag drive ka magdamag konti pa din ang naka projectors...
*blue_gambit,
nice job sa diy. haha kung may abilidad din ako, ganyan na rin gagawin ko hahaha by the way, anong brand ng hid gamit mo? china 55w 4300K? and ano yung projectors mo?
balak ko sana yung audi q5 projectors since malaki naman yung space ng headlights ng car ko. will pair it with a decent 55w 4300K hid sana.
Ano kayang cause nito?
http://youtu.be/kCcPz5vDzgc
Nagsstuck up madalas. Pag pinalo babalik sa lo. Bihira na lang yung di sya magloloko kaya di ko na ginagamit hi beam. Kaysa makasilaw ako.
Sent from my iPhone using Tsikot Car Forums
It seems your proj is Q5 based from the high beam output. Yang projector na yan has very big/beafy solenoid and you can literally hear it engaging. Pwedeng yung shield ay naiipit on the guide. Only way to find out is to reopen
Weird kasi minsan it's working perfectly fine naman pero sobrang bihira. And randomly sya nagloloko. Pag nastuck up sya naghahanap ako ng lubak para bumalik sa Lo or I stop then tap the HL. Hassle lang.
baka di maganda connection o meh problem sa pinag kabitan ng + at - nang contacts nung solenoid....
ground wire at positive supply wire for the solenoid.
try mu sir tignan yung connection points para sure na hindi sa wires o contacts
Was at Circuit Makati last night to check on the Kart track. May ilaw na nga, so pwede nang mag-night race ala Singapore! Anyhow, only the track was lit so I took this chance to photograph the output of the bixenon MH1 (c/o Pao).
I didn't step out of the GS anymore. The camera was positioned roughly above left side view mirror.
Low Beam only
High Beam (of the projector and the oem high beams)
Nangyayari din pala yang stuck up shield sa ibang type ng projectors. Ang alam ko lang na notorious dyan ay MH1.
Agree ako kay sir Ginnova na sumasabit yung shield sa guide kaya hindi sya matulak ng spring pabalik sa low beam position.
Sent from my GT-N7100 using Tsikot Forums mobile app
Pag binuksan ulit yung HL, kailangan na bang palitan yung buong solenoid or shield or pwedeng i-adjust na lang? Matagal na to eh gusto ko ipagawa na sana para magkasilbi naman Hi beam ko.
kung sumabit lang at one time, madali lang remedyohan, kugnd efective ang solenoid hindi ko sure kung nagagawa yun, granting na DIY
Hey guys
Just a quick question , what if Hid is used on a stock projector instead of a halogen? Will the output be same ? Glare rin ba?
you can try it on the driver's side then compare the glare when both are turned on at the same time. then compare the output and how far you see on the road. driving on a dark road there shouldn't be a brighter area before the farthest reach for the dipped beam. this makes driving fast on highways difficult.
