Results 651 to 660 of 747
January 15th, 2014 09:54 PM #651
baka di maganda connection o meh problem sa pinag kabitan ng + at - nang contacts nung solenoid....
ground wire at positive supply wire for the solenoid.
try mu sir tignan yung connection points para sure na hindi sa wires o contacts
January 15th, 2014 09:56 PM #652
January 15th, 2014 10:30 PM #653
Nangyayari din pala yang stuck up shield sa ibang type ng projectors. Ang alam ko lang na notorious dyan ay MH1.
Agree ako kay sir Ginnova na sumasabit yung shield sa guide kaya hindi sya matulak ng spring pabalik sa low beam position.
Sent from my GT-N7100 using Tsikot Forums mobile app
January 15th, 2014 11:30 PM #654
Pag binuksan ulit yung HL, kailangan na bang palitan yung buong solenoid or shield or pwedeng i-adjust na lang? Matagal na to eh gusto ko ipagawa na sana para magkasilbi naman Hi beam ko.
Sent from my iPhone using Tsikot Car Forums
January 16th, 2014 01:23 AM #655
January 16th, 2014 08:43 AM #656
January 16th, 2014 10:52 AM #657
kung sumabit lang at one time, madali lang remedyohan, kugnd efective ang solenoid hindi ko sure kung nagagawa yun, granting na DIY
- Feb 2006
- 771
January 17th, 2014 09:11 PM #658Hey guys
Just a quick question , what if Hid is used on a stock projector instead of a halogen? Will the output be same ? Glare rin ba?
January 18th, 2014 03:26 AM #659
you can try it on the driver's side then compare the glare when both are turned on at the same time. then compare the output and how far you see on the road. driving on a dark road there shouldn't be a brighter area before the farthest reach for the dipped beam. this makes driving fast on highways difficult.
January 18th, 2014 04:47 PM #660
Different halogen projectors react differently with regards to glare. If you are lucky that there is minimal or no glare, the output will improve in brightness but distance and width will almost be the same since these are dependent of the projector's bowl design which didn't change.
Most mall guards already know how to operate power rear tailgates, they just take time to find the...
All New Toyota Corolla Cross
