Page 46 of 75 FirstFirst ... 3642434445464748495056 ... LastLast
Results 451 to 460 of 747
    #451
    some output shots of the 3in D2S bolt-on projector. very nice cut-off beam. colorful,sharp,straight and wide.
    May 2008
    #452
    patulong po mga sirs. pag naka low beam po yung HID projector ko nagdadrop po yung RPM ko na para bang naka on yung aircon.
    TIA mga sir!
    #453
    ano bang hid ang nakakabit sa kotse mo ngayon. may wiring harness na nakakabit or your just using stock headlight wiring to power the ballast
    Dec 2009
    #454
    update lang natin tong tread na to... sir ginnova ito pics nung nainstall na bolt on d2s.. DIY lang din pero gumamit na ako maayos na bulb and ballast
    projectors: bought from sir ginnova, 3 inch koito d2s ata name nito
    ( superb output and distribution nang light)
    bulb: Philips 85122+
    ballast: morimoto d2s 50watts
    shroud: apollo ata name ng shroud
    harness: provided by sir paolo(pdm88 of sulit)
    wiring loom
    2 morimoto relays
    fuse block modification
    #455
    Miko ganda niyan ah.
    Dec 2009
    #456
    nag DIY lang ako.. pina heat gun ko sa labas tapos ako na nag lagay projectors at align... tapos ako source out parts pati lagay harness DIY na din, para makatipid, hehe sulit,
    lakas output grabe, kaka enjoy mag retrofit ng bolt on.. hehe..
    #457
    Quote Originally Posted by miko101130 View Post
    Nice Project... how much did it cost? all-in-all?
    #458
    wiring loom
    2 morimoto relays
    nice one Miko. how much did you get the philips 85122+. I have a pair that's been sitting around. post some output shots. your set-up will definitely outshine most bolt-ons and cost a lot cheaper that having it done somewhere else. might be upgrading my set-up to TL.
    Dec 2009
    #459
    i got the Philips 85122+ from sulit. he was a member of team celerio and only used the bulb for 3 months since he will be selling his car... i got the 85122+ for just 1k!!! and he sold his morimoto 50w ballast for 2k only!!!
    right now meh extra pair na morimoto 50w 5000k na bulb ako, yung philips 85122+ pag sa 50w na ballast mas ok sa mata yung pagka yellow, yung 5000k na bulb parang masyado maputi...
    total cost ko d2
    projectors:7500 ata from sir ginnova
    bulb: 1000 for philips85122+
    ballast: 2000 for morimoto-five 50w
    harness h4: 500
    2 pieces morimoto relay: 500
    heat gun sa banawe: 400
    merienda koh: 200(ahahaha)
    total 11,900 pesos....
    #460
    kakapakabit ko lang din ng bolt-on projectors. kay paolo ng sulit ako kumuha. 7300 all in
    gen5 projectors
    4300k bulb
    55 watts slim ballast
    may free park light pa. hehehe
    sulit na sulit. tagal ko pinag-isipan to. hahaha.
Bolt-on bi-xenon projectors
