Page 21 of 75 FirstFirst ... 111718192021222324253171 ... LastLast
Results 201 to 210 of 747
    Mar 2004
    #201
    Quote Originally Posted by garyq View Post
    SF means Sta.Fe model 2010 tama ba? If correct then I've worked with the Sta.Fe and it is not a G3 projector. First of all G3 is an HID projector. Yung stock ng SF is halogen. Another thing totally iba ang output nila, baka yung profile lang pareho. And another thing is yung stock projector ng SF isa sa pinaka mahinang halogen projector I've worked with and pag nabuksan mo yung headlights ng SF, you will know why. Iba ang design nung halogen projectors ng SF.
    you are right. i was referrng to my 2010 Santa Fe. yung oem projector nya ganyan din kasi ang cut off parang sa picture ng g3 ang cutoff. lalong naging visible nung pinalitan ko ng HID bulb na 6000K na 50watts. ganyang ganyan itsura ng cutoff nya.
    pag pinalitan ba ng g5 or g8 na projector e kalas lahat ng headlight? meaning mag cut and then seal na lang uli?
    magkano total magastos pag pinalitan ng g5 or g8 na projector? and magagamit ko pa ba ang existing HID bulb ko na H7 6000K 50 watts kung sakali projector lang palitan?
    #202
    mukhang hindi kakasya yung G5/G8 sa headlight mo. meron kasi kasama na built-in shroud yung g5/g8. the mini h1 could fit.
    Jan 2008
    #203
    G5 with philips 85122+ bulbs
    Jan 2008
    #204
    Jan 2010
    #205
    Quote Originally Posted by kkreuk18 View Post
    Thanks sa pics sir kkreuk
    Sa asphalt road malaki ba improvements?
    Thanks...
    Jan 2008
    #206
    meron pero di naman masyado malaki pero ok. magkakaalaman kapag umuulan kung meron improvement
    #207
    the philips bulbs can take 55watts ballasts with no issues. you would see a big improvement. that's the reason why I chose this bulb even though mahal. I'm still checking if the projector bowl can take the heat but no issues so far.
    Feb 2011
    #208
    sir kkreuk, anu gamit mo na ballast? 55w?
    Jan 2008
    #209
    Quote Originally Posted by zacks_888 View Post
    Nope standard 35w ballasts
    Jan 2010
    #210
    Quote Originally Posted by Ginnova View Post
    Post ka naman ng pics bro
Bolt-on bi-xenon projectors
