Results 661 to 670 of 747
- Feb 2006
- 771
January 18th, 2014 06:05 PM #661
- Oct 2008
- 525
May 8th, 2014 05:45 AM #662
May 16th, 2014 04:42 AM #663
Ano kaya problem nung hid ko. Pag initial na bukas ayaw niya umilaw. Kelangan ko pa iflash o high beam para siya umilaw then saka ko ibabalil sa low. Minsan namamatay pa rin kaya flash ulit ako para umilaw. Mga 2 years na rin ata yung projector. Gen 3 ata yung sa akin. Kelangan na kaya palitan ung bulb? San ok bumili? Thanks
- Feb 2011
- 129
June 6th, 2014 12:07 AM #664hi sir, for those na nag retrofit or bolt-on
okay rin ba gamitin to as pass or flashing light? or pag nag retro fit na, kailangan bawasan yung pag flash ng headlights?
June 6th, 2014 12:44 AM #665
If you used BiX in your retrofit, and your low beams ARE ALREADY ON you can use the flash your lights as it only flips down the solenoid blocking the light. You can do this everytime till your car is old and gray. No need to change your habit.
Remember that this instance is applicable only when your HIDs are in low beam. Doing otherwise will stress your ballast and bulb.
Also, it won't work (high beam won't light up) as HIDs needs 4-5 seconds of warming up before going full brightness, much unlike halogen bulb.
Hope this help clear things up.
- Feb 2011
- 129
June 6th, 2014 08:21 PM #666i guess, i need to look for other options since I rely too much on high beam during the day as pass light more than using the horn (unless I always use the HL even in the day)
June 17th, 2014 01:04 AM #667
^ Fast HIDs are already in the market. You don't need a second to turn them on.
June 23rd, 2014 07:19 PM #668
Was at Circuit Makati last night to check on the Kart track. May ilaw na nga, so pwede nang mag-night race ala Singapore! Anyhow, only the track was lit so I took this chance to photograph the output of the bixenon MH1 (c/o Pao).
I didn't step out of the GS anymore. The camera was positioned roughly above left side view mirror.
Low Beam only
High Beam (of the projector and the oem high beams)
July 2nd, 2014 01:28 AM #669
Q5-R / Philips 85122/ Matsushita Gen V Ballast
Low Beam and High Beam
Posted via Tsikot Mobile App
- Sep 2007
- 46
July 2nd, 2014 01:43 AM #670hello po. i've read this thread from page one. Please advise what would be a decent setup for my B14 sentra. Planning to get Koito Q5 kasi parang siya yung nakikita ko na ok ang reviews. Kakasya kaya yung projector sa headlight ng B14? Saka iniisip ko po kung oorder ako online or mas mabuti na dito nalang. sa mga nagreretrofit para sa warranty claims
high idle RPM at engine start
