Results 391 to 400 of 747
September 18th, 2011 07:23 AM #391
both mh1 and g5 are chinese products and are also available locally. yung nasa TRS is magandang klase yung bulb ( rebased philips ) at ballast ( morimoto ballast )
Bi-xenon Morimoto Mini Stage III Kit (H1)
Adapter Plate: H4
Ballasts: Morimoto 3Five (35w)
Bulbs: H1: XB35 4300K
CCFL Angel Eyes: No
Projectors: LHD (North American Standard)
Re-sealing Glue: No Thanks
Shrouds: Apollo
Wire Harness: Relay: H4/9003
$325.00
The mh1 kit with XB35 bulbs and additional shroud ( Apollo - yan ang bagay sa Jazz ) will cost $325. BTW there's an option to have 20% discount on a stage III kit.
September 26th, 2011 12:37 AM #392
TRS replied to my email and they sent me a PDF how to guide for the Bi-xenon Morimoto Mini Stage III Kit (D2S). Its very simple and a direct bolt on for my Jazz.
* Ballasts: 5) Morimoto 5Five 50w
* Bulbs: Morimoto 5Five 4300K D2S
* CCFL Angel Eyes: No thanks
* Projectors: LHD (North American Standard)
* Re-sealing Glue: No Thanks
SubTotal
$300.00
Does a 50w bulb and ballast have a shorter lifespan than a 35w?
Honda Jazz/Fit Gallery
http://www.hidplanet.com/forums/album.php?albumid=162
September 26th, 2011 10:11 AM #393
mini h1 , mini d2s and other bolt-ons as the name implies are direct bolt-ons to the reflector. no cutting is required. very easy to install.
yes, bulb life will be shorter when powered by 50watts ballast but your ok since you're getting the 5five bulbs.
September 26th, 2011 12:23 PM #394
mga bro pwede magtanong, gusto ko mag try ng g5 binebenta swak naman sa presyo pero gusto ko malaman ang bulb nito kung replaceable, i ask xenonoptics eh sabi specific daw. sabi dito D2S ano ba talaga heheh
yun morimoto h1 ba mas maganda ba compare sa g5. interms of widest beam.
ang mga choice ko kasi limited lang
- g5
- morimoto h1 mini
interesado ako mag upgrade. sana may makasagot mula sa owners experience.
September 26th, 2011 01:29 PM #395
jmpet,
please search the hidp forums for the latest group buy, maybe you'll still catch it and piggyback to get up to 25% off. it applies to stage 3 and up or a similar shop cart. sayang din, 1/4 price off which will go down to ₱9,732 ($225).
mag group buy na lang kayo ng grupo mo. 25 sets minimum itong huling group buy.
September 26th, 2011 02:07 PM #396
everyone, the group buy is still ongoing. the code is TacomaWorld25 at checkout. you guys might wanna try it out
September 26th, 2011 04:12 PM #397
September 27th, 2011 06:44 AM #398
Uy thanks indiej! Laki din ng nabawas.
Bi-xenon Morimoto Mini Stage III Kit (D2S) $300.00
Shrouds
Apollo
Wire Harness
Relay: H4/9003
Re-sealing Glue
No Thanks
Projectors
CCFL Angel Eyes
No thanks
Bulbs
Ballasts
Order Total
Sub-Total:
$255.00
UPS Ground:
$13.33
Coupon TacomaWorld25:
-$45.00
Total:
$268.33 (around 11.5k)
Sa tingin niyo mga sirs sa xenon optics kasi meron sila 14k na Morimoto pero H1 lang yung bulb. Ano kaya mas OK
September 27th, 2011 10:20 AM #399
i think i came across some negative comments about the mini d2s while browsing at hidp. i just skimmed those threads because i'm just not interested with those. please search that forum about that. you can also read about the mini h1 on sale for $75 compare it with mini d2s. i hope you haven't comitted
September 27th, 2011 01:57 PM #400
most of the mini h1/d2s users at hidp changed to better projectors / OEM projectors after using them for some time. but if youre coming from halogen headlights then the mini's will be a big improvement. if you're planning to use them for a long time , go for OEM parts especially if your daily usage is high. Aftermarket bulbs tend color shift and loose output quite fast.
high idle RPM at engine start
