Page 40 of 75 FirstFirst ... 3036373839404142434450 ... LastLast
Results 391 to 400 of 747
    #391
    both mh1 and g5 are chinese products and are also available locally. yung nasa TRS is magandang klase yung bulb ( rebased philips ) at ballast ( morimoto ballast )
    Bi-xenon Morimoto Mini Stage III Kit (H1)
    Adapter Plate: H4
    Ballasts: Morimoto 3Five (35w)
    Bulbs: H1: XB35 4300K
    CCFL Angel Eyes: No
    Projectors: LHD (North American Standard)
    Re-sealing Glue: No Thanks
    Shrouds: Apollo
    Wire Harness: Relay: H4/9003
    $325.00
    The mh1 kit with XB35 bulbs and additional shroud ( Apollo - yan ang bagay sa Jazz ) will cost $325. BTW there's an option to have 20% discount on a stage III kit.
    Mar 2005
    #392
    TRS replied to my email and they sent me a PDF how to guide for the Bi-xenon Morimoto Mini Stage III Kit (D2S). Its very simple and a direct bolt on for my Jazz.
    * Ballasts: 5) Morimoto 5Five 50w
    * Bulbs: Morimoto 5Five 4300K D2S
    * CCFL Angel Eyes: No thanks
    * Projectors: LHD (North American Standard)
    * Re-sealing Glue: No Thanks
    SubTotal
    $300.00
    Does a 50w bulb and ballast have a shorter lifespan than a 35w?
    Honda Jazz/Fit Gallery
    http://www.hidplanet.com/forums/album.php?albumid=162
    #393
    mini h1 , mini d2s and other bolt-ons as the name implies are direct bolt-ons to the reflector. no cutting is required. very easy to install.
    yes, bulb life will be shorter when powered by 50watts ballast but your ok since you're getting the 5five bulbs.
    Apr 2010
    #394
    mga bro pwede magtanong, gusto ko mag try ng g5 binebenta swak naman sa presyo pero gusto ko malaman ang bulb nito kung replaceable, i ask xenonoptics eh sabi specific daw. sabi dito D2S ano ba talaga heheh
    yun morimoto h1 ba mas maganda ba compare sa g5. interms of widest beam.
    ang mga choice ko kasi limited lang
    - g5
    - morimoto h1 mini
    interesado ako mag upgrade. sana may makasagot mula sa owners experience.
    Oct 2008
    #395
    jmpet,
    please search the hidp forums for the latest group buy, maybe you'll still catch it and piggyback to get up to 25% off. it applies to stage 3 and up or a similar shop cart. sayang din, 1/4 price off which will go down to ₱9,732 ($225).
    mag group buy na lang kayo ng grupo mo. 25 sets minimum itong huling group buy.
    Oct 2008
    #396
    everyone, the group buy is still ongoing. the code is TacomaWorld25 at checkout. you guys might wanna try it out
    #397
    Quote Originally Posted by kicks4us24 View Post
    - g5
    - morimoto h1 mini
    Perfect fit yung D2S bulbs sa G5 na pang H4 housing. I'm using Philips D2S OEM bulbs. note you need to buy a d2s connector for the convertion.
    Mar 2005
    #398
    Uy thanks indiej! Laki din ng nabawas.
    Bi-xenon Morimoto Mini Stage III Kit (D2S) $300.00
    Shrouds
    Apollo
    Wire Harness
    Relay: H4/9003
    Re-sealing Glue
    No Thanks
    Projectors
    CCFL Angel Eyes
    No thanks
    Bulbs
    Ballasts
    Order Total
    Sub-Total:
    $255.00
    UPS Ground:
    $13.33
    Coupon TacomaWorld25:
    -$45.00
    Total:
    $268.33 (around 11.5k)
    Sa tingin niyo mga sirs sa xenon optics kasi meron sila 14k na Morimoto pero H1 lang yung bulb. Ano kaya mas OK
    Oct 2008
    #399
    i think i came across some negative comments about the mini d2s while browsing at hidp. i just skimmed those threads because i'm just not interested with those. please search that forum about that. you can also read about the mini h1 on sale for $75 compare it with mini d2s. i hope you haven't comitted
    #400
    most of the mini h1/d2s users at hidp changed to better projectors / OEM projectors after using them for some time. but if youre coming from halogen headlights then the mini's will be a big improvement. if you're planning to use them for a long time , go for OEM parts especially if your daily usage is high. Aftermarket bulbs tend color shift and loose output quite fast.
Bolt-on bi-xenon projectors
