Results 201 to 210 of 747
March 29th, 2011 05:27 PM #201
you are right. i was referrng to my 2010 Santa Fe. yung oem projector nya ganyan din kasi ang cut off parang sa picture ng g3 ang cutoff. lalong naging visible nung pinalitan ko ng HID bulb na 6000K na 50watts. ganyang ganyan itsura ng cutoff nya.
pag pinalitan ba ng g5 or g8 na projector e kalas lahat ng headlight? meaning mag cut and then seal na lang uli?
magkano total magastos pag pinalitan ng g5 or g8 na projector? and magagamit ko pa ba ang existing HID bulb ko na H7 6000K 50 watts kung sakali projector lang palitan?
March 29th, 2011 06:50 PM #202
mukhang hindi kakasya yung G5/G8 sa headlight mo. meron kasi kasama na built-in shroud yung g5/g8. the mini h1 could fit.
March 30th, 2011 11:20 AM #205
March 30th, 2011 11:57 AM #206
meron pero di naman masyado malaki pero ok. magkakaalaman kapag umuulan kung meron improvement
March 30th, 2011 12:49 PM #207
the philips bulbs can take 55watts ballasts with no issues. you would see a big improvement. that's the reason why I chose this bulb even though mahal. I'm still checking if the projector bowl can take the heat but no issues so far.
- Feb 2011
- 64
high idle RPM at engine start
