Results 51 to 60 of 74
August 4th, 2014 10:35 AM #51
August 4th, 2014 01:30 PM #52
Well, in a direct comparison of 6000K output with 4300K -- same type of bulb, same enclosure -- there's definitely better visibility in the rain with the 4300K because it's slightly more yellowish. Comparing the 6000K LED output vs OEM yellowish, and that's another story. With great output comes great glare as well, kaya si glenn manikis patay sindi sa LED niya.
August 4th, 2014 05:50 PM #53
Is there such a thing as "yellow" LED's?
With today's unpredictable weather, IMHO yellow(ish) coloured lamps is the way to go.
August 4th, 2014 07:33 PM #55
The problem with using LED is purely in the optics. Nothing exists yet as an aftermarket product that can emulate the cut-off that is present in standard automotive low-beam headlamps. In that sense, it should be illegal to use LEDs, from a certain intensity, to be used as driving lights.
LED DRLs by design are operated at relatively low-intensity. So even if they don't employ a cut-off, it is less likely to cause glare to oncoming drivers. Some cars even lower the intensity when you turn the headlamps. Although, I'm starting to see LED DRLs that blinding, day or night. These too, should be banned, IMO.
August 4th, 2014 07:34 PM #56
LED DRLs by design are operated at relatively low-intensity. So even if they don't employ a cut-off, it is less likely to cause glare to oncoming drivers. Some cars even lower the intensity when you turn the headlamps on. Although, I'm starting to see LED DRLs that are blinding, day or night. These too, should be banned, IMO.Last edited by oj88; August 4th, 2014 at 08:28 PM.
- Feb 2011
- 129
August 4th, 2014 11:17 PM #57kain ka yema. itabi mo yung balat pagtapos tapos dikit mo sa led bar
anyway, you can easily tint it. If you want something that is not permanent, maybe you can look for a aftermarket cover or custom made acrylic cover, then ayun yung i-tint or painted with clear yellow paint.
August 6th, 2014 11:25 AM #58
some LEDs have the option to install a snap on transparent yellow cover to give you the yellow effect.
- Sep 2013
- 505
August 22nd, 2014 12:27 AM #59
August 23rd, 2014 02:33 PM #60
^ 4300K bulb is not yellow but white. Warm white. A yellow bulb is about 2600K to 3200K.
A yellow LED is more on the shade of amber.
I think a yellow halogen 2600K may have better effect than a yellow LED in the rain.
Sent from my HM NOTE 1TD using Tsikot Car Forums mobile app
do your homework. each car/model will have their own problems.
[Tsikot official] Where do you buy used cars?
