Yup alam ko isa yan sa regulations when you have those lamps, dapat nakalagay ang cover when in city limits.
Kung kailangan kumuha ng permit, kumuha bago magpakabit. Kung wala namang ganyang batas, walang makakapigil sa isang taong magpakabit nyan.
Sana lang maging responsible sa paggamit ang mga mayroon. Hindi naman porket may nakakabit na led bar a$$hole na agad. E kung sa offroad nya talaga ginagamit, walang issue dun.
*nori, kung magpapakabit ka at alam mo naman ang tamang lugar at panahon ng paggamit, sige lang.
Alam ko hindi parepareho ang mga led lightbars, may mga wide ang beams pero short throw, may mga narrow beam pero malayo ang distance parang hyperspot spot. Research on what you need para sulit din ang pagpapainstall. Get legit lightbars too like Rigid para tama ang beam pattern sa kailangan mo.
http://www.rigidindustries.com/conte...led-light-bars
Posted via Tsikot Mobile App
LTO regulations limit it to two units mounted at the same level or below the level of the oem headlamps (since this was drafted when euro cars had foglamps built into their headlamp housings).
Again, these regulations were made way before LED tech became commonplace.
I have one on the responder unit (Medical Control 1) but limit its use to roads with no oncoming traffic or if the vehicle in front and traveling in the same direction is 350 or more feet away.
We also use it for scene lighting when we work.
Doc Otep illegal pala maglagay sa roof? Tama lang pala plan ko maglagay sa nudge bar ng 2 lamps.
Eto kaya ok lang
m.philips.com.ph/m/car-lamps/x-treme-ultinon-led-car-lamp-12834unix2/prd/
Introducing the NEW Philips X-treme Ultinon LED Fog Bulb!
Meron sa blade hella fog lamps that use a led bulb with reflectors. Maliwanag pero hindi sabog yung ilaw kasi naka focus gawa nung reflectors
teka teka teka... di naman LED bar yung kakabit ko ah.
ulitin ko nga, yung iba nabasa lang yung LED at fog galit na galit na agad... yung bullbar may provision for two foglamps, currently may 4" halogen foglamps na nakakabit pero flood ang throw niya hindi spot kaya mahirap gamitin kahit out of town. so ang plan ko palitan siya ng LED foglamps pero sa ilalim ng headlamps ko na ilalagay, to minimize glare if meron man. may seller kasi ng foglamps na focused ang beam niya parang flashlight. di sabog. yun ang target ko. okay?
pero naisip ko lang, if feasible man yung plano ko above eh kakabitan ko na rin ng foglamps or LED bar yung bullbar. pambulag lang sa mga irresponsible LED bar users out there. pwede rin pang flash instead na high beam.
and yes, i know the rule about foglamps above the headlamps as illegal. yung number of foglamps ang di ko alam.
On light bar users:
To be politically correct, put opaque protective covers on them when driving on public roads. This will signify your commitment to NOT misuse the light whether intentionally or unintentionally. In fact, putting caps or covers on auxiliary/off-road lights is law in some countries to make the vehicle road-legal. They're only allowed to remove them when they're off-road.
It's just sad that the local law enforcement agencies don't have the mental acuity to see these things.
There ia something better - a remotely operated search light. Pwede mo itutok dun sa naka high beam sa likod.
Pero bakit ba siya nag high beam? Baka naman you're doing 100kph on the overtaking lane and hugging it? Sabi nga ni nijababes, "for no good reason".
sir... what brand of LED Bar do you guys recommend? Lagay ko sa roof...
im planning to buy tomorrow 41" may nag qoute sakin 19k with installation RS brand
yung isa naman 41" curved led bar generic cree 22k with install na din...
responsible enough naman ako na kung saan ko lang dapat gamitin yan...
